SOURCE: how to reset parrot v5 10c language and memory?
all of the manuals etc are on www.parrot.com for the various models I would start by looking there, hope it helps.
SOURCE: Parrot Car Kit "no signal" detected problem
No signal is normally a result of the power wires been the wrong way round, disconnect the parrot, check memory and switched live are correct the try the unit again, if it still dont work then it will need new software hard wired into it. Find your nearest Parrot engineer from parrot.com
SOURCE: How to reset parrot v5 10c
hi
hold in green and red button together for 20 seconds, kit should beep, then re-pair phone code is 1234
hope this helps
SOURCE: it will not connect
First, try to check into settings -> pair with phone and ensure that you do not have already five phone paired with the kit. If yes, just delete one of the phone. If not, you have most of the time a message on the phone saying "pairing fail" or other.
Check to the phone that you do not have the infrared activated. Does the phone find the kit?
You can also trying to retreive the battery of the phone during one minute and put it on again. The try to pair once again.
You can make a crossing test with an other phone to ensure that the kit is working.
you will need to delete any old devices from the memory.go to SETTING / PAIRED DEVICES / move onto a paired device and press the middle button , then scroll down to delete and press middle button, then press green to confirm.
