Question about Sanyo VPC-X1250 Digital Camera
What does it mean when your Sanyo VPC-X1250 digital camera says "System error?"
  • lexy_roys Jun 05, 2011
    I can't get on my camera.
  • 1,140 Answers
Try to reset your cammera settings to default
try to change memory card first.
try to format your memory card
Posted on Jun 05, 2011
SOURCE:
Cant turn on image stabilizer
When you are in recording menu, third line in the menu says Photo Stabilizer. But if tat one is grated out, that means it is not available. The manual never says anything about the stabiliser function.
So if your camera allows you to stitch between stabiliser on or off, please let me know.
Jan 02, 2014 | Sanyo VPC-X1250 Digital Camera
My laptop dont recognize the sanyo x1250
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Mar 04, 2012 | Sanyo VPC-X1250 Digital Camera
I have the Sanyo x1250 and it dropped with the len extended. When I turn it on, the lens goes partcially in and out while making a clicking noise, and after a few seconds of this, it says system error on...
Lens errors (system errors on Sanyo's) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Oct 17, 2011 | Sanyo VPC-X1250 Digital Camera
I have a Sanyo digital camera, model: VPC-X1250; it now takes blurry pictures where you can't tell what the subject is even when i am inches away from the person's face. it also turns on, makes a...
hi According to your information, somehow your camera has lens unit defective. Your local repair shop would charge around $ 35 to 75 depend on what really want to charge. Thanks and best regard!
May 24, 2011 | Sanyo VPC-X1250 Digital Camera
I Dropped my Camera and Now the Lenses are Not working Properly and it keeps saying "System Error"
Lens Errors (a.k.a. "Zoom" and "System" errors) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth a try.
May 12, 2011 | Sanyo VPC-X1250 Digital Camera
How do you charge a sanyo VPC-T1495?
My wife got this for Christmas. The battery was installed from the manufacturer backwards. After looking inside I noticed 3 pins that matched the connections on the battery. Flipped the battery around and viola. I'd bet other people are having the same issue.
Apr 24, 2011 | Sanyo VPC-X1250 Digital Camera
How do i replace the LCD screen on my sanyo digital camera?
Replacing the LCD screen will not be cost effective. Compared to the cost of buying a new camera, it will cost more than it is worth.
Mar 01, 2011 | Sanyo VPC-X1250 Digital Camera
Help!! Sanyo VPC-E760 Digital Camera driver for Mac OSX
the driver is not separately available for Sanyo VPC-E760
Aug 06, 2008 | Sanyo Xacti VPC-S60 Digital Camera
Sanyo VPC-X1250 Digital Camera Logo
275 people viewed this question
Top Sanyo Cameras Experts
teddyboy
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
