Mg is a unit of mass, ml is a unit of volume. There is no conversion between them. A mg of water occupies about a ml, a mg of lead takes up a lot less space.
For that product 1mL weighs 1 mg. 1 for 1.
750 mg over 6 hours is equivalent to 750 mL over 6 hours.
In mL per minute, you calculate 750 mL / (6*60) m = 25/12 mL/min
Now just find out of may mL are in a drop. Divide the result above by the number of mL/min and you get your result in drops /min
I assumed that gtts stands for drops (in French gouttes) per minute.
For pure water 1 ml is 1 gram. So 80 ml is going to be 80 g which is 80 000 mg. This all comes form the base relation 1 litre (1000 ml) is 1 kg (1000 g).
For other substances, it will be a bit more or less than 1 gram in a ml, but not much.
It would help us both to know what is the injection, we are not the police.
You cannot convert a unit of mass (mg) to a unit of capacity (volume). Mass and volume of a specific substance are related through the mass density (mass per unit volume).
What you have seems to be a dilution problem but it is not formulated completely. Please try again with necessary details.
mg is a measure of mass, ml is a measure of volume. There is no direct conversion between the two. A ml of water masses one gram, while a ml of gold masses over 13 grams.
