Welcome to Fixya. If you want to connect you Wii to the internet
wirelessly first we need to know the settings of your router. Listed
below are the steps on how to access your router. You need a working computer connected to the router to access it follwed by the steps on how to connect our Wii.
How to access the Router:
1. You need to know the ipaddress of your router. You can refer to the manual or check the Default Gateway
of your computer (Make sure that you connect the computer to the router
using an ethernet cable for you to get the Default Gateway). Click on START then RUN. Type CMD on the small box on the lower left of the screen. Type IPCONFIG on the black window and get the value of your DEFAULT GATEWAY (it starts with 192.168.x.x)
2. Open a Browser, Type the DEFAULT GATEWAY
on the address bar of your Browser. It will ask you for a username and
password. (Refer to the manual of your router or post a reply so that i
can provide you the username and password of your router)
3. Go to the Wireless Settings Page of your router. Look for the SSID or the Network Name and the Network Key or Passphrase. You can personalize it so that you can easily remember the details.
4. Make sure you connect to your SSID and enter the Network Key to make it secure.
Now that we have the information needed lets connect your Wii to the internet.
1. Select Wii Settings
2. Then Internet then Connection Settings
3. Search for an AP or SSID
4. Input Security Key or Network Key
5. Test the Connection.
Other Suggestion
Did this connection used to work but has suddenly stopped? "Power
cycle" your router by unplugging it from the power outlet. Wait a few
minutes, and plug the modem back in. Wait a couple of minutes for the
modem to initialize, then plug in the router. Try to connect the Wii
and test for proper response.
The Wii may have detected and set itself to the wrong security
type during the initial connection set up. Try creating a new
connection file and going through the connection process again but be
sure that when the Wii asks for a security code, the type shown on
screen (WEP or WPA) is what your router is set to. If it is different
Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker.
Thanks for using Fixya.
