Computers & Internet Logo
Posted on Jun 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My notebook toshiba q10 n250, dont have backup and or Any operating system ( after a format) so i tryed to install windows xp via an usb bootable, but now the bios dont recognize the hard disk (maybe drivers sata is missing, but dont know how to solve it), so i cant install windows. regards
Mike
Level 3:
  • Master 4,383 Answers
  • Posted on Jun 04, 2011
Mike
Master
Level 3:
Answers
4383
Questions
Helped
1261525
Points
17064
You need the install program from Toshiba and should be able to download it from the Toshiba site. The drivers, OS and programs were most likely on the D:\ drive, before it got formatted.
How to format desktop having windows xp installed on it the dvd writer is not working can i format it from usb pendrive
You would need to create a bootable USB stick, and then use tools installed on it to format your drive. full instructions Create Bootable USB Flash Drive
tip
How to create a bootable USB using Vista or Windows 7
Having a bootable USB is very essential, especially if you are a Netbook user. Using bootable USB to install an operating system (OS) not only makes the installation faster, but also saves a DVD.Creating or using an USB drive to install Windows operating systems is very easy if you follow the below mentioned steps.
Here we assume that you are using either Vista or Windows 7 to create a bootable USB.
1. Insert your USB (4GB+ preferable) stick to the system and backup all the data from the USB as we are going to format the USB to make it as bootable.
2. Open elevated Command Prompt. To do this, type in CMD in Start menu search field and hit Ctrl + Shift + Enter. Alternatively, navigate to Start > All programs >Accessories > right click on Command Prompt and select run as administrator.
3. When the Command Prompt opens, enter the following command:DISKPART and hit enter.LIST DISK and hit enter.Once you enter the LIST DISK command, it will show the disk number of your USB drive.
4. In this step you need to enter all the below commands one by one and hit enter. As these commands are self explanatory, you can easily guess what these commands do.
SELECT DISK 1 (Replace DISK 1 with your disk number), CLEAN, CREATE PARTITION PRIMARY,SELECT PARTITION 1ACTIVE,FORMAT FS=NTFS(Format process may take few seconds),ASSIGN,EXIT.
Don't close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Insert your Windows DVD in the optical drive and note down the drive letter of the optical drive and USB media. Here I use "D" as my optical (DVD) drive letter and "H" as my USB drive letter.
6. Go back to command prompt and execute the following commands:
D:CD BOOT and hit enter. Where "D" is your DVD drive letter.CD BOOT and hit enter to see the below message.BOOTSECT.EXE/NT60 H:(Where "H" is your USB drive letter)
7. Copy Windows DVD contents to USB.You are done with your bootable USB. You can now use this bootable USB as bootable DVD on any computer that comes with USB boot feature (most of the current motherboards support this feature).Note that this bootable USB guide will not work if you are trying to make a bootable USB on XP computer.
on Dec 18, 2010 • Computers & Internet
tip
How to install Windows Vista/7 using bootable USB storage device
How to install Windows Vista/7 using bootable USB storage device Requires:
- Windows Vista/7 DVD 0r installation source (setup backup files)
- A 4GB USB 2.0 Storage device (Its recommeded to use USB 2.0 device for optimal performance)
  • Plug your USB storage device.
  • Run CMD and execute the following commands one by one.
  • Diskpart
Run Disk parition utility
  • List disk
To get disk index that is used to pefrom disk paritioning.
  • Select disk 1
Selects disk to pefrom disk paritioning.
  • Clean
Flush your existing all USB drive's partitions.
  • Create parition primary
Creates a parition as primary parition.
  • Format recommeded
Format your USB drive w/ recommeded parameters. (No need to worry about file system format)
  • Active
Set the parition as active to hold bootmgr.
  • Exit
To quit Diskpart utlity
Now copy all Windows Vista/7 files to USB storage device... thats all.
  • Boot your PC w/ it, you can install Windows Vista/7 via bootable USB storage device.
Note: If you face any trouble to boot w/ it or unable to boot, try this
FIX.
I:\Boot\Bootsect.exe /NT60 I: Where I: is the drive letter of USB storage device
on Aug 29, 2010 • Computers & Internet
I want to format it all,and change my security code coz i forget it
Hello
In case you want to install a windows 7/vista operating system, you need the following.
Bootable Geniune Windows DVD or ISO.
USB Pendrive (minimum 4 GB).
please follow the instructions here and make the pendrive bootable and boot and reformat the system to your specification. incase you dont have usb booting facility, use the DVD and boot it. Make sure u have data backup.
incase you are referring to a mobile phone use the phone reset (factory reset) option available in the security option under the settings menu.
THanks
How are you, expert i m just wondering that i try to downgrade my dell notebook, that the os is vista, to windows xp. but i cant install xp instead. i want to reset it to the factory or reset to vista....
if you have windows xp bootable cd boot with that and format your system and install windows xp operating system .but before doing formating take backup of your impotant data and download the driver for laptop windows xp compatible.
Hope this helps. Please rate my response.
Thanks.
Have a good day
I have a PC with C2D E7200 2.53GHz Processor, 250GB HDD & 2 GB RAM, I HAve 5 Partition on the HDD and i have partitioned it as C: 20.5GB__D: 68.3GB__E: 68.3GB__F: 38.3GB__G: 37.2 GB. On C Partition WIN...
#1 Use windows backup in Windows 7 to create a full system backup of the OS to DVD or a removable drive. (And well as any data on any other partition)
#2 Repartition drive to roughtly 50 50 split
#3 Install XP to partition 1, Install 7 to partition 2 then restore the backup of 7 to partition 2,
2answers
How to reformat my laptop,toshiba satellite u 300.thansk
with what operating system?
There are two ways...
(1) take the hard drive out and connect it to another computer, right click on the drive, and click format
(2) You need a windows or other operating system disk....just start it like you were going to install windows, and select advanced disk options (it's a link, easy to overlook but it's always there)
You can not format a disk with a running operating system on it.
There are other "bootable" disks you can also format the hard drive with...an Acronis Backup boot disk, probably a Norton Ghost boot disk....things like that...not all bootable CDs, but usually a backup or disk imaging program will allow you to format a hard drive
My laptop is LG X-NOTE e500 G.A2H2A2 .Present operating system is Window vista i want to load operating system xp service pack 2.plzzzzzzzzz suggest
You need to have a Windows XP SP2 bootable disc. Just go to BIOS and enable the boot from CD/DVD Insert the Windows XP disc It will boot with the bootable disc and you just need to follow the on screen instructions. You will need to format the HDD and do a clean installation which will result in data loss. Please make sure that you take a backup of all your important data files before changing the operating system.
For any further assistance please feel free to revert with comments.
Thank you for choosing Fixya
2answers
I wan to format my laptop (HP Pavilion Entertainment Pc), but i don't how ? could you please help me out ?
In order to format and install operating system again you need a dos bootable floppy or cd to format....
Best solution is that try windows xp or windows vista bootable cd ,it will format your hardd drive and also will install the operating system....
Good Luck.
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
2answers
Rebuild
A PCMCIA CD drive will work, but only some models. Toshiba makes one, and it would be your best bet.
Grand Canyon Tech
Grand Canyon Tech
