Lenovo IdeaPad Z560 Notebook Logo
A
Anonymous Posted on Jun 04, 2011
If the battery is fully charged when i plug the charger stopped charging or not in Lenovo z560 ?
Prashant Sharma
Level 3:
Genius:
  • Master 1,127 Answers
  • Posted on Jun 04, 2011
Prashant  Sharma
Master
Level 3:
Genius:
Answers
1127
Questions
0
Helped
237351
Points
3825
Hi
Battery is not charge bcoz this already charged. please don;t over charge your Laptop battery this is harmfull for laptop
Anonymous
Level 2:
Sergeant:
  • Expert 183 Answers
Anonymous
Expert
Level 2:
Sergeant:
Answers
183
Questions
0
Helped
26256
Points
525
Welcome to FixYa
When the battery is fully charged and you still have the ac adapter plugged in then the battery would no longer be charged. The computer would then be running on ac adapter power.
hope this helps
2answers
Battery not charging
Sounds like it could be two things with that, first look at the battery symbol, is it flashing orange or is it green. If its flashing orange means you have a bad battery, if its solid green all ok, if its switching between green and yellow its charging. if the symbol isn't lit at all it doesn't detect your battery and try to remove and reinsert battery. Next look at the plug light, is it green?
IdeaPad Z560 79% available "Plugged in but not charging" message
Bad battery? Is the battery a replacement? Test cord/charger.
Lenovo Ideapad Z570: Battery indicator shows the Power is plugged in & charging. But the Battery charge percentage doesn't increase. How to fix this?
The battery might be nearing the end of it's useful life and needs to be replaced. The battery only lasts for so long then it has to be replaced.
Buy a battery on ebay base on your computer's Make and model, not the model of the battery.
1helpful
Lenovo z560 getting overheated and switched off
if you keep the mains charger plugged in all the time then this can cause the battery to heat up. if you use the laptop in the same position all the time then try removing the battery for use or when the battery is fully charged then remove the charger, this will also preserve the lifespan and battery operation.hope this is of help to you,
How many hours does lenovo laptop takes
When using a fully charged battery ;
6 cell - about 5 hours
9 cell - about 7 hours
Hope this helps
Thank you
Dennis
1helpful
The laptop lenovo z560 does not switch on. With battery it shows 2 short flashes of battery charge idicator, an one long (about 10 sec) and than nothing is happening. Withou battery nothing happens after...
Hi smialkovskyi,
With this specific concern that you do have, unable to turn on your Lenovo Z560, there 3 components that need to be checked. Your battery, the AC adapter (charger) and as well as the DC In port.
1.Based on what you have said, with the battery alone you have noticed that it's led indicator will show however still can't turn on system. Battery seems to be in good condition however no enough charge to turn on the system.
2. For your AC adapter, when you're using it without the battery nothing happens. To check if this is defective try using another AC adapter that is compatible to your unit. If your computer turned on using another AC adapter then your charger needs replacement. (You may also try using your charger to other unit where it is compatible, just to test).
3. However, if after doing the previous instruction and still system won't turn on then it could be the DC In port which is defective. This port is built in to *********** board.
After doing all these you need to contact Lenovo. They might be replacing your charger or *********** board if system is under warranty.
Hope this helps.
Thank you for using Fixya.
3helpful
2answers
Lenovo Z560 laptop battery charge drops from 50% down to 7% suddenly. And after that, i need to charge the laptop where it gets charged till 99% only. What is the problem i am facing now?. I purchased the...
A sudden drop from 50% to 7% means that the battery is faulty, it is simply a case where it is not holding any charge. I would suggest you contact the seller and check if the battery is under warranty. Hope this helps and good luck.Any question please feel free to ask.
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
