First thing to check is your brake lights. The brake interlock for the shifter relies on the switch that turns your brake lights on. If it's not working, you won't have brake lights OR the ability to move the shifter out of park. In an emergency, most of these vehicles have a small plug near the shifter that you can remove, push a button, and move the shifter without pushing the brake pedal.
Good luck.
SOURCE: My gear shift is stuck and will not move from park
do the brake lights work? the system has a lock out that keeps you from moving out of park unless the brake circuit is activated, hence no brake lights no park lock out release, if the brk lights do work u most have a stuck or defective park lock out solenoid.
SOURCE: gear shift won't move out of park sometimes
look for transmission shift interlock solenoid fuse.or a bad brake switch will cause transmission not to come out of park.
SOURCE: shift gear is locked cannot shift out of park gear
this is for newer malibu's, but may work for you too.
#08-05-22-009: Intermittently Brake Lights (Stop
Lamp) Do Not Function Correctly, Extended Travel to Shift Out of Park,
Cruise Control Inoperative, DTC C0161/C0277 Set (Perform Repair as
Outlined) - (Dec 4, 2008)
Subject: Intermittently Brake Lights (Stop Lamp) Do Not Function
Correctly, Extended Travel to Shift Out of Park, Cruise Control
Inoperative, DTCs C0161/C0277 Set (Perform Repair as Outlined)
Models: 2004-2007 Chevrolet Malibu, Malibu Maxx
2008 Chevrolet Malibu Classic
2005-2009 Pontiac G6
2007-2009 Saturn AURA
Condition
Some customers may comment that intermittently the brake lights do not
function correctly. Other symptoms may include extended pedal travel
required to shift out of PARK, cruise control does not function
correctly, and DTC C0161 and/or C0277 may be set.
Cause
The most likely cause of this condition is high resistance due to
terminal fretting corrosion in the body control module (BCM) C2
connector (specifically pins C2-18, C2-31 and C2-59).
Correction
DO NOT replace the BCM for this condition. Disconnecting the C2
connector, adding dielectric silicone grease and reconnecting the C2
connector per the procedure below will correct the high resistance
condition due to terminal fretting corrosion.
Remove the right side front floor console side trim panel to access to the Body Control Module (BCM).
Locate the C2 connector on the BCM.
Unlatch the C2 connector and disconnect the C2 connector from the BCM.
Reconnect the C2 connector back on the BCM and re-latch.
Repeat Steps 3 and 4 (this step cleans up the terminal fretting corrosion).
Using the Tech 2®, verify the brake pedal position sensor (BPPS) voltage is between:
• 0.88V - 2.11V (for 2004-2006 model years)
• 0.73V - 1.47V (for 2007-2009 model years)
Check for proper operation of the brake lights.
• If the brakes lights are operating properly, remove the C2 connector again from the BCM and proceed to Step 8.
• If the brake lights are not operating properly, proceed to Step 12.
Apply dielectric lubricant (clear gel) GM P/N 12377900 (In Canada, use
P/N 10953529) on the BCM C2 pins (apply with a one-inch nylon bristle
brush) on all the C2 connector pins (this will treat the pins against
Reinstall the right side front floor console side trim panel.
Using the Tech 2®, check that the BPPS ratio is equal to BPPS learned home when the brake pedal is not depressed.
• If they are equal, brake lamps should be operating correctly and no further steps are necessary.
• If they are not equal, perform the Brake Pedal Position Sensor Calibration procedure in SI to complete the repair.
Check the brake lights for proper operation. If incorrect, refer to SI and perform normal diagnostics.
Source(s):
gm tech
SOURCE: Oldsmobile gear shift stuck in park
shifter is getting bowned up on colum or on transmission see why
SOURCE: The gear shift is stuck in park. The wheel moves
Make sure you have brake lamps. The shift interlock solenoid is powered by the brake lamp switch.
The
shifter needs to be inspected. The shifter assembly is got misaligned, it has
to be open and realign.
There
are many other possibilities. But if it was working right up till now and
suddenly this occurred then its shifter
assembly alignment issue.
Also
i suggest you to refer these gear shift issues, which are mostly noticed. These
are direct links with appropriate solutions to
the specific problems of gear ****.
GEAR SHIFT ISSUES
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html
http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html
http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html
http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html
http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html
http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html
http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html
http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html
http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html
http://schematicsdiagram.blogspot.in/2012/06/2007-hyundai-santa-fe-will-not-shift.html
These details will help.
Thanks.
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html
transmission sticks in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html
Transmission not engaging in first
gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html
Vehicle only goes
in First gear?
Engine will not go out of park mode?
http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html
Car stuck in park?
http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html
Car will not come
out of Park?
Automatic
transmission will not go into high gear?
Car wont downshift
sometimes?
Transmission
will shift into drive?
Auto wont shift
from park?
http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html
Car Transmission
will not go into Park mode?
Shift indicator
directly goes to 2nd when key is turned ON?
Third gear missing
and engine losing power?
Vehicle has whining sound in gear?
Hard to shift gears on Manual
transmission?
Car hard shift at slow speeds?
Automatic transmission shift lever
hard to move on cold mornings?
Gear shifts hard?
Vehicle noticed sluggish
delayed shifts while driving?
This will help.
Thanks.
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html----transmission sticks in first gear?http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html-----Transmission not engaging in first gear?http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html-----Vehicle only goes in First gear?
----Engine will not go out of park mode?http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html----Car stuck in park?http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html-----Car will not come out of Park?
Automatic transmission will not go into high gear?
---Car wont downshift sometimes?
----Transmission will shift into drive?
-----Auto wont shift from park?http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html----Car Transmission will not go into Park mode?
-----Shift indicator directly goes to 2nd when key is turned ON?
----Third gear missing and engine losing power?
-------Vehicle has whining sound in gear?
-----Hard to shift gears on Manual transmission?
------Car hard shift at slow speeds?
---Automatic transmission shift lever hard to move on cold mornings?
------Gear shifts hard?
-------Vehicle noticed sluggish delayed shifts while driving?
This will help.
Thanks.
gear?
Vehicle only goes
in First gear?
Car stuck in park?
Car will not come
out of Park?
Automatic
Car wont downshift
sometimes?
Transmission
Auto wont shift
from park?
Car Transmission
Shift indicator
Third gear missing
transmission?
Gear shifts hard?
This will help.
Thanks.
gear?
Vehicle only goes
in First gear?
Car stuck in park?
Car will not come
out of Park?
Automatic
Car wont downshift
sometimes?
Transmission
Auto wont shift
from park?
Car Transmission
Shift indicator
Third gear missing
transmission?
Gear shifts hard?
This will help.
Thanks.
gear?
Vehicle only goes
in First gear?
Car stuck in park?
Car will not come
out of Park?
Automatic
Car wont downshift
sometimes?
Transmission
Auto wont shift
from park?
Car Transmission
Shift indicator
Third gear missing
transmission?
Gear shifts hard?
This will help.
Thanks.
gear?
Vehicle only goes
in First gear?
Car stuck in park?
Car will not come
out of Park?
Automatic
Car wont downshift
sometimes?
Transmission
Auto wont shift
from park?
Car Transmission
Shift indicator
Third gear missing
transmission?
Gear shifts hard?
This will help.
Thanks.
gear?
Vehicle only goes
in First gear?
Car stuck in park?
Car will not come
out of Park?
Automatic
Car wont downshift
sometimes?
Transmission
Auto wont shift
from park?
Car Transmission
Shift indicator
Third gear missing
transmission?
Gear shifts hard?
This will help.
Thanks.
is this a floor shifter?
