Unplug the set! Snap the trim ring off the front of the set and you may find a few screws or the front screen may just pop off. Then you can clean the screen and mirror. Be sure not to bump the color guns this will change the alignment of them. Be careful not to spill anything in the set. This is a relative easy fix.
Sony KDP-57XBR2 Need to clean mirror picture dull from dust.Removed screws at bottom front of screen no other screws noticeable. There is a trim ring referenced in this article wandering how much force is required to remove the front screen to get inside to clean reflector glass. Is there a place I should start in order to remove this trim ring?
