SOURCE: Power Acoustik PTID-4005 BYPASS BRAKE
Just ground you brake wire directly to the metal frame. It should work fine. Goodluck.
SOURCE: PTID-5800
That is goin to be a lot of work!! here's how u do it. You know the bire you attach to your break? Ground that to the frame and it will play while driving.
SOURCE: bypass having to use the parking brake on power acoustik ptid7250
no, you can't, because watching a video while you drive is an insanely stupid thing to do.
SOURCE: how can i bypass the brake deal so i can watch dvd
some radios are stupid and look only for a voltage on the pin and says yep the brake is on
some radios are clever and look for voltage on the brake pin and also the virecles speed ect
so i recomend that you first connect the brake pin on the radio to ground and test the radio
if it doesnt work then conenct 12V to the pin and see if it works
i recomend that you get someone in the passengers seat and go out for a quick drive to make sure
my radio is the clever one and it knows when the car is moving or not
SOURCE: how to bypass the parking brake on a nesa DVD deck
what i did was put the pink cable(parking brake) and connect it to ground(black) of the stereo harness and then both of them hook it up to the black cable of the car which is ground or negative.
