Question about Sunbeam Dehumidifiers
Running but not collecting water. The air filter is clean.
  • Sunbeam Master
  • 43,501 Answers
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Jun 05, 2011
SOURCE:
Dehumdifier not collecting water.
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
Oct 01, 2010 | Whirlpool AD50USL Dehumidifier
My whirlpool dehumidifier fan runs, but no water is being taken out of the air; cleaned the filter and still no change; dehumidifier was purchased in August 2008.
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Take care.
Aug 15, 2010 | Whirlpool Dehumidifiers
My dehumidifier is running but not collecting any water. I have cleaned the filter and it still wont collect water. Is it broken?
Good luck.
Aug 15, 2010 | LG Dehumidifiers
Dehumidifier is running but, no water is being extracted from the air.
Take care.
Aug 14, 2010 | Windchaser WDH928 Dehumidifier
I have a Comfort-Aire BHD-301 dehumidifier that runs but does not collect water. What should I do?
Take care.
Aug 09, 2010 | Comfort-Aire BHD-301 Dehumidifier
Unit runs but no water collect and humidity is at 65 presently
I unscrew the cover were's the air is ****'s inside and I just clean with water pressure.I beleive I have to do this every six month.The problem was;no more water collect,less air came out and the unit was very hot.Only clean the filter is not enough!!
Aug 24, 2009 | Danby Dehumidifiers
Kenmore dehumidifier runs but won't collect water
If you haven't done so already, try removing and cleaning the inlet filter screen which is almost certainly just behing the inlet grille. It may slide upwards out of the casing or downwards unto the bucket area. If this is blocked with fluff then no moist air will get to the cold pipes, so little or no water will be extracted. There's also a chance that the humidity sensor is clogged with fluff, so fooling the system into thinking the room is pretty dry, in which case the compressor will probably not run.
A running compressor can usually be detected as a deep throbbing from the machine. If it is running, but not cooling the pipes behind the intake grille, then you may have lost the refrigerant from the system via a leak. If the air coming out of the machine is warm (caused by the compressor running) but there is no water produced this may be the cause.
Explore along these lines and let me know what you find.
Cheers, D
Jul 31, 2008 | Dehumidifiers
Kenmore Dehumidifier
if the compressor is running it sounds like a refrigerant problem or dead compressor in both cases its not cost efective to repair dan
Jul 05, 2008 | Haier HDN655E Dehumidifier
Dehumidifiers Logo
267 people viewed this question
Top Sunbeam Dehumidifiers Experts
gggg
Raymond Richards
Raymond Richards
Tom Chichester
Are you a Sunbeam Dehumidifier Expert? Answer questions, earn points and help others
