SOURCE: Oven quit, bake not working, replaced thermostat, now broil works, still no bake
Your problem may be the bake relay on the clock or wiring.try changing that
SOURCE: baking element
oh bleep, right? well, if you're lucky this will get you going again. 1. disconnect power to range. 2. remove back metal cover just above range power cord (usually 5 quarter inch hex screws) 3. look for burnt off wire leading to/from bake element. If yes, 4. strip ends of broken wire and splice with ceramic wire nut if no 4. bad news. replace ERC (electronic range control) you fried something on the board. It's got the clock display and all the electronics behind it.
SOURCE: oven does not get hot enough to bake
Probably a failure to get 240 volts to those elements.
If burners work, then it's probably an oven CONTROL(S)l failure. Test them if you know how. Very difficult to find parts for a stove that old.
Testimonial: "very helpful as all 4 burners work but oven does not get hot enough to bake. As suggested I will search for new oven temp control switch. Thank you "
SOURCE: Bake element for Maytag MER5765RAS did not work.
look inside the breaker box..find the 220 breaker to the range...make sure both sides are in the on possition....if not then only 110 volts are going to the range instead of 220...hope this helps..thanks
SOURCE: On Frigidaire Self-Cleaning Range, bottom oven
Sounds like the bake element is out. Remove it and test it for continuity. If you need further assistance please feel free to contact me.
