SOURCE: Switching from PC monitor to an HDTV monitor
Yes, this product will do the job. An easier solution, although probably more expensive, would be to use a video card with dual outputs. Using a video card with dual outputs would allow you to see the computer's video on both screens simultaneously.
SOURCE: Star logic 19inch computer monitor power adapter STD-1205
You can use a power supply for a CCTV system. Here is a website that has one, it is for a DVR4220, code STD-1205
SOURCE: Star view 5 start up (Virgin Media)
Press menu on handset.Standing on installation press numbers 1570. Changes to nagravision. Press OK. This will get you to key providers. Scroll right till you get to telewest/virgin.Use handset to put codes in 00 first then 01.Press store after each set of codes.
Telewest/virgin codes updated 12/10/09
00 - CF 53 OC 33 79 61 71 85
01- 52 5E 8D 45 FC 75 F6 4A After this press exit to the start.
You might have to do installation.
Press menu. On installation press 1668.While on telewest press OK. It should input all channels.
Testimonial: "very helpfull was just wondering... Hiya Lexusmickey thanks for the help with my star view 5 box. I was just wondering how I have to connect the box? I have it connected to my tv via a scart lead and the main menu comes up. However I was wondering if I need to connect anything else to the box? I also have virgin media broadband do I need to connect the box to my modem or to the cable from the wall? I have also read quite a bit about needing firmware or a usb to put in the back of the box? Any help would be greatly appreciated."
SOURCE: power cord
If the voltage is the same, and the current of your replacement adapter is equal to / greater than the original, it should work perfectly fine.
BUT..
The only thing to pay attention to is if it is AC or DC. AC requires nothing more for you to do. DC however, will require that you have the proper polarity: PLUS (+) and MINUS (-) on the mating plug contact points. If you guess at this, you have a 50/50 chance of turning it into "toast". If the socket is unmarked, contact the manufacturer to obtain polarity information BEFORE connecting!
Testimonial: "Dear Steve,thank you for your quick responce. I made the mistake of pluging it in and it did say DC on the hard drive. I was stupid and lucky because it seems to be woking fine. Should I asume that the polarity: PLUS (+) and MINUS (-) on the mating plug contact points are correct or could it still turn to toast? THANKS once again, Gordy"
Why are you posting? Is there a question?
