This error code indicates that drain times are longer than expected. This could be a problem with one of the washer parts
including the drain pump itself, how the drain hose enters the stand
pipe, or maybe something is stuck somewhere in the drain system and
is preventing the water from flowing properly.
Make sure the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
Remove the three screws that hold the lower access panel in place.
Here you will find the pump and the all important sump clean out, or as
we like to call it, the coin catcher.
