Re: How do i delete a 'Message for You' on a BT T7100?
Lift the handset then press #65 then press HOLD button it will delete the "Message For You".... just send a "thank you" message to my [email protected]
CORRECTION : Lift the handset then press Feature button then press #65 then press HOLD button it will delete the "Message For You".CORRECTION : Lift the handset then press Feature button then press #65 then press HOLD button it will delete the "Message For You".
You can't post conmments that contain an email address.
Go to settings, General, blue tooth and remove any "other" previous paired BT devices & Turn off BT, then go to Sett. General, scroll down to reset and reset network settings, this will not delete anything. Power off BT speaker. after iPad re-boots turn on BT Speaker First, make sure BT is off on iPad as well as WIFI-wait like 10-15 seconds and then turn BT on in iPad it should see your speaker now and let you pair it up.
Lift the handset then press Feature button then press #65 then press HOLD button it will delete the "Message For You".... just send a "thank you" message to my [email protected]
go into menu, go to "play message", scroll down to "all messages" press the tick button, when the messages play press X (secrecy) button. you have to delete them one by one hope this helps
Im assuming you have BT Broadband? If you delete BT Helper or something along those lines from Start -> All Programs -> Startup that should fix your problem.
eventually contacted the BT team via telephone and apparently this is a common problem when using BT products with Talktalk & Virgin. To overcome this in the majority of cases, dial 1571 and connect to your voicemail, listen to the options and finally delete all messages. Hope this can be added to your list of solutions.
