Take the lens to a repair facility. When you've recovered from the shock of the cost, look on Ebay for a replacement. FYI, it may be better to get an f1.7 lens instead - far far cheaper, and the f1.4 was notorious for less than optimum optics wide open. You'll only lose half a stop or so, which is negligible.
SOURCE: film won't advance
Pentax ME Super was one of my favorite camera, small and clean shutter release. But it has been about 25 years since it was manufactured. They happen to use rubber break within shutter unit and as any rubbers, it started to deteriorate and melt between the shutter-blades. This prevents the complete cycle of the shutter and jams the winding. You may be able to unjam the winding but eventually you have to overhaul the shutter unit. Overhaul charge is around $100 in US repair market. -James
SOURCE: Is my ME Super toast?
It doesn't need batteries to shoot. You can use it on manual without batteries, but the exposure meter won't work (if you know what you're doing you can go by). But the stuck mirror should be fixed. It could be just plain dirty/rusty/bent etc.
The advance lever might be gone since it won't 'click'. A professional shop can fix it, but the one you tried doesn't sound very professional...
SOURCE: pentax me super camera, not working wind on lever
The clip spring broke jambing the advance gear. by forcing, the tab on the advance shaft broke.
take or send your camera to a camera repair shop for an estimate cost to repair.
there are no new parts for this model so the repairs could be expensive.
there should be no cost for an estimate.
