Belkin Play N600 Wireless Dual Band Router (722868807453) Logo
Anonymous Posted on Jun 02, 2011
I have a Belkin N600 HD (FD78301). It was working fine but after few weeks the light turned orange from green. I started having intermittent problems accessing the internet. The router has the following setup: 1) Eco mode ON to reduce intensity of the green light 2) self healing ON - router will reboot at 3:00 am everyday restarting the router did not fix the issue. Finally I reset to factory defaults and then set up my router again which made the router light green. Is this any indication of any kind of hardware problem. I have the latest firmware 1.00.30 uloaded from belkin site: F7D4301-8301_WW_1.00.30.bin thanks.
Anonymous
Level 2:
  • Expert 212 Answers
  • Posted on Jun 03, 2011
Anonymous
Expert
Level 2:
Answers
212
Questions
0
Helped
69447
Points
653
Hi jaijeetc, There is no need to worry about a hardware problem. The orange light is just telling you that you didn't have an internet connection. So no, there is no need to worry about a hardware problem. Cheers, Alex
Hi my Belkin N300 wireless moden router works for about ten minutes, then the green light turns to a flashing orange. Any tips on why this happen and any solutions. It dose get a bit hot dose this make a...
If the green light is one of the port lights, then your network is switching into 10mbs (Orange = 10mbs, Green = 100mbs) - it may be a dodgy cable but more likely a faulty network card in your PC.
I have my router hooked to my cable modem. Its been working great. Then all of a sudden i have no wireless, then no cable modem. The router an orange or red color. When i unhook the router my cable modem...
Hi Jason
To get the connection back all you need to do is just connect the modem to the router to the yello port & computer to any gray port on the router.
& unplugg the power from the router first & then from the cable modem. Wait 30sec & plug the power to the cable modem first & then once the modem is on completly plug the power to the belkin router.
The light will turn green & start working.
This is an intermittent connection.
To avoid this happening over & over kindly update the firmware in the router.
you can login to the belkin.com/support web site to download & know the procedures to update the firmware in the router.
Thanks
1helpful
Hi am having connection issues with my belkin play n600 router can u help me?
i bought this router earlier in the year. after trying to set it up and having problems i called belkin, who told me to call my internet supplier. virgin tried but couldnt help and told me ring belkin again. after trying everything they told me for about an hour and still no joy, i took it back to the shop.
14helpful
Panasonic PT-LB10SVU green light flashing,then orange,lamp light
i just replace the lamp, and don't have any light coming from lens,starting green (after a few seconds,green become to flash2_bing.gif), then turning on orange and lamp light flashing...please i need help, fan working perfect...i don't have a remote,is a problem, or not
Belkin F5D7230 A Works fine until it stops. Displays no power light, orange wired connector light/s Green modem light. will respond to a power off- power on change (mostly)
try using anaothe one of the same make , if it works then that one is faulty( get a new one and test it out to see if it works) then return it!
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
