Computers & Internet Logo
Posted on Jun 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I was running 2 scsi drives in a raid 0. One drive failed, how can i retrieve the files off the the still working drive, and can i?
Anonymous
Level 2:
  • Expert 212 Answers
  • Posted on Jun 02, 2011
Anonymous
Expert
Level 2:
Answers
212
Questions
0
Helped
69500
Points
653
Hi there, Sorry to break the bad news, but when one hard drive fails in a RAID 0 configuration, all data is lost. Your only chance is to take it to a professional data recovery center, where you could be charged hundreds, or thousands of dollars for a data restore. Seagate will do these recoveries for you. RAID 0 has no redundancy, unfortunately. Sorry about that, Alex
2helpful
I have two WD1600s, in RAID 0 configuration, on my Dell XPS, XP. One has failed. Can I just buy another one and reload the OS? Will any WD1600 do?
If you have a Raid 0, then both drives are tied into one. You could remove the bad drive, and just use the leftover one. But you would need to disable RAID in the BIOS.
Unless you know how you benefit from a Raid 0, I do not recommend keeping a Raid 0 if you have important files you need to keep.
you could also buy another drive, disable Raid, and install the operating system on the first drive, and keep leftover files like pictures etc on the second drive.
tip
FAIL-SAFE FILE SERVER AND COMPUTER SYSTEMS If your data is very important, you...
If your data is very important, you should consider doing regular data backups because hard disk will fail at some at some stage in the future. This is especially true when you get an error message"hard drive is about to fail".
Depending upon how critical your computer or files server to you or your business, you should consider building a fail-safe computer or file server system using RAID technology. RAID means "A Redundant Array of Inexpensive Disks" and there are several levels of RAID.
For details of different RAID levels - click on this link -
http://searchstorage.techtarget.com/sDefinition/0,,sid5_gci214332,00.html
The most common of the fault redundant RAID systems are -
RAID 0 + RAID 1 provides fastest data transfer Mirrored hard drives.
RAID 5 is one of the most popular system, it data striping across hard drives with error correction. It has excellent performance with fail-safe system and allows for hot swappable hard drives.
There should be redundant powers supply inside the computer or file server in the event of a power supply failing.
Another consideration is to install a UPS (uninterruptible power supply) to prevent a computer or server shut down from power outages, as this will corrupt your data.
These systems do not mean you should not back up your data on a regular basis.
on Oct 20, 2010 • Computers & Internet
I have dell 4600 pe serveri want to install Server2003 os i have configured raid 1 on the machine every thing is fine but! on boot process it display message no Boot Device Found Press F1 to continue F2...
The hard drive needs to be set as the first SCSI ID device boot device..
The hard drive needs to have the jumper set to SCSI ID 0, the CD and FDD can be set to SCSI ID 1 and SCSI ID 2. No SCSI devices can have the same SCSI ID number unless it is on a different SCS controller.
I want to retrieve data from an old 50-pin hd from my old mac. Anybody got a solution?
There are two ways of retrieving data from a SCSI hard drive.
1. Connect the SCSI hard drive to a different SCSI connector on the same data cable, make sure this hard drive has a different SCSI ID from the first hard drive or other SCSI devices in your system. When you boot up your MAC you should see the second SCSI hard drive, You can then copy off your data or remove the redundant files and keep the old hard drive in your system as a 2nd hard drive.
2. Connect the old SCSI hard drive to a SCSI USB hard drive adapter. Then connect it to the USB port on the MAC and you should see this as an external hard drive.
2answers
No SCSI Chips found on the adapter
This is a serious problem and you could easily guess wrong and blow away your data.
Good news is that Dell servers have lifetime support. Without a warranty you will have to pay for any parts you need but, if you are lucky, you won't need any. If you do get the part # from Dell and check eBay for it.
Get the Service Tag from the server and call Dell Technical Support.
You can get the phone # from their website.
2helpful
2answers
Boot problem with IBM xseries 206 - SCSI Drive and SATA drive
Refer to user's manual how to set the boot order in BIOS.
Pci ide controller for third hard disk
You need to enter into scsi bios first, then do an autodetect for hard drive, this will set the IDE/SCSI hard drive on raid controller.
To enter SCSI control you need to press the same key stated on screen on startup (F6 I assume) I think F3 is just boot settings.
If the card do not enter regularly in CMOS settings for the raid then this card is defective.
Raid 0 on Intellistation 6221?
That particular work station comes with both IDE and SCSI drive interface controllers. The IDE drive should be used for your OS. The SCSI drives for your data storage. Now, the issue is to get the SCSI to work in RAID_0 as I understand.
You iwll need a RAID controller such as Adaptec AHA-3940AU WD SCSI Host Controller, which may be found on eBay (used) for a very affordable price. The driver software may be downloaded directly from Adaptec, so I suggest you do that in the iterim peroid, and store drivers on a USB thumb drive.
Hope this helps you.
2helpful
3answers
Drive array problem
Hi Nick ,
As of now you can Select "F2" to accept data loss and re-enable logical drive. This Load OS Normally .
It seems that one of the HDD in the RAID 5 has failed , Did you notice any LED indications like red or amber on the HDDs ?? if so get that hdd replaced . Make sure the Failed HDD is replaced .
You can run the Array Diagnostic Utility from HP System tools to check the Failed Drives and also frimware version of the controller . If the frimware is not latest Update it from HP website. DL380 G4 should have Smart Array 6i controller .
Hope This was Helpful
cheers :)
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
