Dehumidifiers Logo
Posted on Jun 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Danby Dehumidifer SDR408H. It seems that the compressor won"t cut in. The machine will turn on.
  • Anonymous Mar 30, 2014
    fan does not go on when i push start
Anonymous
Level 3:
  • Danby Master 43,501 Answers
  • Posted on Jun 05, 2011
Anonymous
Danby Master
Level 3:
Answers
43501
Questions
0
Helped
10834890
Points
101584
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Have Danby dehumidifier, turned on first time this season,fan & all displays worked fine, but compressor never went on. Removed back panel & compressor is very hot.
Be careful. i do not know. set at highest setting and let it run. while running, reduce setting to the lowest over a few minutes. at a lower setting you should be able to tell that the compressor has started. run it for 5 minutes, then
unplug your machine. next, feel the cooling coils to see if they are very cold. if they are not cold, your unit needs to be serviced.
1helpful
I have a danby dehumidifer model number DDR6011R It keeps saying the humidity is only 30..(Which I know it's higher) so the compressor isn't kicking on. Help??
It sounds like the humidistat sensor failed on the unit. You'll need to replace that sensor to be able to get the unit operational again
I have a danby dehumidifier...when I turn it on the fan goes on, but the actual dehumidier does not...the light about the first button does not light up. What Can i do?
It's probably in the wrong mode. This could be from a number of causes including you have not emptied the water chamber.
1helpful
DEHUMIDIFER WONT START
empty the tank, and clean the dust off of the condenser in the front or clean the filter. if it still won't turn on, may have a bad sensor or a siezed compressor.
2helpful
It runs, the fan works in Hi and Lo, the compressor seems to work, it seems to blow warm air if the compressor is running and cold air when it is not. The mode switch does something but I am not sure...
Take it to a metal scrap yard and turn it in the copper and buy a new one. Buy a different brand.
Sorry to be so blunt but dehumidifiers are very cheap and disposable not many people work on them. If this help please rate me and do a testimonial.
The Danby Millennium Dehumidifer goes not condense any more. Have unpluged the unit, cleaned all of the filters. Is there a way to reset the unit from the controls?
If you unplugged the heater for 12-15 minutes, after turning OFF the Master On/OFF Switch, the electronics should reset themselves. Also, be sure that you don't have the humidity level set to high. Anything above 60% wont' extract any moisture to speak of. If your unit doesn't have an LED display, set the unit on Minimum.
Hope this helps you. Please let me know. Thanks.
Same Problems as Everyone Else
I have a Danby DDR 458EE dehumidifer that I purchased May 27, 2008.
Used it for the summer and stored it until May this year. At the end of July of this year it started not working. It freezes up. Called Danby, they told me it was out of warrenty and to take to a repair shop. Problem being it was leaking freon so have it recharged. Called the repair shop and they explained that it is a closed system and if it is leaking Freon, they can not recharge it until the leak is found and repaired. It's against the law to discharge freon in to the atmosphere. Stated cost to repair it would be greater then buying a new one. Called Danby back and explained what repair person said. Still waiting to see if they will give me a pro-rated refund.
44helpful
3answers
ON-LINE REGISTER FOR 2 EXTRA MONTHS WARRENTY- HOW?
I purchase a compact bar fridge from Walmart and am trying to register it on - line
Dehumidifer Initial Purchase
You may get a better effect if you ventilated the crawl space.
Top Danby Dehumidifiers Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
