Tape can not be inserted backward in.It is impossible to to insert cassette inside video wrong way. If it is not ejecting its eject switch might have got broken by physically pulling its cassette compartment outward before closing last time. Its mini switch is very fragile in all sony models. so only way is to take to technician to bring it out.If i were you,I would buy used one from ebay at lower price than repairing.
Common problem with this mechanism. In order to fix the problem you will have to replace part called CHASSIS LS. Expensive repair, probably not worth the effort.
To the best of my knowledge 8mm VTR's have not been available for some time now. On the other hand there are plenty of Hi8 cameras and players available after market. eBay is a great source. Keep in mind that Hi8 cameras and decks will also play standard 8mm video tapes. There are also many video tape transfer services that will transfer your 8mm tapes to DVD or other formats of your choice. Just Google "videotape transfer service"
You need a computer with video card capable to take composite or super video input if you have that then the software it come with that video card then you can transfer from your CAM to computer and burn into DVD or HDD
Cheers
The camcorder most likely is not detecting the tape, you have a bad sensor and these sensors all come on a flex type board and the flex board is mounted on the chassis surface. This will mean that the entire mechanism will meed to be diassembled, and is a very big and costly job. My opinion is that this repair will run you abut 250 to 300 bucks and this camcorder is not worth this as new camcorders are under 200 bucks. Good Luck
