all windows dead, not told, and and down both dead?
did not check all fuse first even the GAUGE fuse. blown?
relay marked MAIN ,is missing or not energized, if not , windows will be dead.
NO RHD HERE NOR HI ACE IN USA.
SO NO BOOKS.
MOST CARS HAVE
CB FOR THAT A LARGE AUTORESETTING CIRCUIT BREAKER .
YES THE FUSE BOXES ON RHD CARS ARE NOT LIKE LHD.
WISE YOU ARE STATING IT AND RARE HERE.
THERE ARE 3 WAYS TO GET THIS DATA.
BUY THE SERVICE MANUAL
FROM DEALER
OR GOOGLE IT.<<<my post is only based off google finds. period.
OR LOOK FOR CB IN ALL FUSE BOXES. THEY ARE LABELED. ON 99%
Are all windows dead for up and down.?
all door controls switches dead, for windows, left and right cab?
if yes ,sure the CB is bad.
car engine starts and runs ok
all other electrics work ok. ???? is the gauges in cluster working too?
just windows all dead?
back in 94 ,no BCM brain here, just wires ,switches and fuses. (and win motors)
get the truck serviced in a shop.the guy with a voltmeter there knows what to do .
for sure.
watch out some TOY use fuseable link for windows. get the manual first.
on some years that old. or CB.30-amp./
window motors use lots of power. all windows up (button) on ICEd up day
uses huge currents.
so the power feed has huge relay, there. called PWR relay
and a huge fuse feeding windows controls.
this current high does not pass through the ignition switch wrecking it
'it sources from PWR relay. safe and sure.
30amps rated or more. this relay and its fuse.
Hi ACE.
example 1.
top right fuse a CB 30amp
the left fuse is GAUGE fuse, if blown MAIN relay is dead. 7.5amp fuse
i key on and check 12vdc at relay pin 3 below. output side.
if dead, then bad fuses or relay ,. or bad ground left.
