Bosch Classixx WFL 2066 Front Load Washer Logo
Posted on Jun 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Key is flashing all the time. Its completely locked me out. It won't let me do anything. I've tried switching it on and off again like you do with computers to no avail. Please help. My machine is a Bosch Classixx 6 1200 Express washing machine. Thanks Eileen
Anonymous
Level 3:
  • Master 436 Answers
  • Posted on Jun 02, 2011
Anonymous
Master
Level 3:
Answers
436
Questions
0
Helped
188671
Points
1420
If its showing a key symbol then the child lock is on.Press and hold the start/pause button in for several seconds and this should take the child lock off and start to work again.
  • 1 more comment
  • sheenarate Sep 15, 2011
    thanks - saved me some money!!
  • Anonymous Feb 27, 2012
    Phew! Thanks!
  • Diane Shields
    Diane Shields Mar 10, 2015
    Thank you so much just done that an it work.Thats them grandkids lol
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Sep 03, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
11158
Points
Press and hold Delay Time/Clock Button until door lock light goes out about 6 seconds.
I have an Aquarius washing machine. The start button is flashing but isn't doing anything when pressed. The on/off button won't switch the machine off and I've tried pressing t
It might indicate that it is locked, If you have the owners manual, there is a list of all the fault codes. You could always try rebooting i.e. unplug it then plug it in again
Key won't turn in ignition on 2006 chevy cobalt
on a lot of these late model computer base cars when battery power get low the computer gets confused. try this disconnect the neg. battery cable. charge the battery. reconnect and try again. my son cobalt battery went bad key was stuck in the igntion. good luck.
1helpful
Need to bypass the security fob. Won't start
You can bypass the fob IF you know the security code.
DO NOT sit on seat, lift bike off kick stand, or anything else that will activate the security mode!
Turn IGN to IGNITION.
Quickly (within 2 seconds) hold BOTH turn signal switches until confirmation signal (KEY icon flashes at fast rate, in odometer window, a flashing "-" will be followed by 4 more dashes = "----")
Enter 1st digit (a) in PIN by pressing LEFT turn signal switch (a) times (i.e., 5 times for the number 5)
The 1st "-" will become the 1st digit (i.e., "5")
Press RIGHT switch signal 1 TIME.
The 1st digit is stored and the dash will flash.
Enter 2nd digit (b), and repeat sequence until done.
After the 5th digit is entered, the KEY icon stops blinking, and the system is disarmed.
The system will stay off until the IGN switch is turned off.
If at any time during disarming sequence an error is made, wait 2 minutes before trying again.
2answers
SD Card Problems with Vivitar Vivicam 5118!
What size is the memory card. If it's larger than 4GB then it won't work in the 5118.
Try using another card. Don't format it in your computer but do format it in the camera before trying to take pictures.
1997 chevy malibu anti theft system how do I fix this problem The car won't start I believe the car is in the anti theft mode
The late-90's GM Passlock system (e.g. 1997 Malibu, Regal, Impala, etc.) has a part around the ignition tumbler that goes bad and no longer reliably detects the valid key. In that situation, the "Theft System" light will slowly flash and the carburetor is cut off so the engine won't start. The time-out on the system is 10 minutes - you don't have to do anything, you don't have to disconnect the battery, the key can be out of the ignition -- it's just a time delay. After 10 minutes, the light goes out and you can try again (but if the key is again not detected, the light will start flashing again and you have to wait another 10 minutes)
Someone else, who had this problem, told me to remove all other keys from my keyring. The weight of the other keys pulls on the ignition key causing the key to be unreadable. It has been 7 weeks since I have been doing this and have not had a problem
1999 CHEVY LUNINA WON'T START BATTERY AND
Check the dash once you turn the key to the run position the passlock runs a security check using a set resistance value through the chip in the key. If the security light begins to flash the reading it received was incorrect or it didn't get a reading at all. You can try reseting the value it is looking for by turning the key to start then releasing it. After 10 minutes turn it off then cycle it start again leaving it in on for 10 minutes then back to off then one more time. After the third cycle has completed for a total of 30 minutes. You should be able to turn the key on and start the vehicle. If the light continues to flash their is a problem with the chip in the key or the connections within the ignition its self. Both are common but a Pass Lock Relearn as described above will usually adapt to the poor connection values. Hope this helps.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
