SOURCE: Oil pressure light is blinking.
It's very possible a coincidence and that the flashing oil light is the oil pressure switch. I'd check it out immediately to make sure there's sufficient oil flowing through the engine. Merely jump starting the car shouldn't have knocked anything loose so to be on the safe side, assume there's an oil pressure issue. You were right to not use the car in the interim.
SOURCE: VW Beetle won't start. Just bought new battery 2
Does the starter turns the engine or not???
Testimonial: "Thanks for the help! I'll try it out and see what happens"
SOURCE: Replacing 2006 VW Beetle headlight How do you do
This is based on my 2001 Beetle, so hopefully they didn't make it any more complicated by the 2006 model year.
Open the hood and look at the inside of the headlight housing. Going from the back of the housing toward the front, there's a metal clip, then a plastic lever, then a little rectangular button with dots on it. These are all right next to each other. Pop off the metal clip, press down on the little rectangular button, then pull up on the plastic lever. It's kind of like a childproof pill bottle cap, I guess. Once you've done all those maneuvers, the headlight housing should slide out the front. Then you can unplug the wires and replace the whole unit, or open up the unit and replace just the bulb.
Since you're working on the driver's side, you'll also have the added joy of trying to work around the battery compartment. You may have to take the battery cover off to get enough room.
SOURCE: Sounds like it doesnt want to start then epc and
I'm going to bet you need a new battery. Car batteries don't last forever, and that you got 4 years on the original is pretty good. Take it to a WalMart. They've got a good warranty on car batteries when you buy a good one for about $80.00..
Testimonial: "Thank you so much!!"
