Question about Casio Privia Px330 Px-330 88 Key Digital Piano New
My Casio Px 330 keyboard is about 1.5 years old. After the instrument has been played for 20 minutes or so, one note (D above middle C) sounds very loud regardless of how hard it is struck. The problem is intermittent, though it may be more pronounced when the damper pedal is used. No other notes show the problem thus far; but I want to have the keyboard serviced and want to give the repair shop a heads up on what to be looking for on the entire keyboard.
  • Casio Master
  • 5,603 Answers
This is a problem with one of the two contacts for that key. The contacts close at different times as the key is depressed and the time it takes between is measured as velocity which is used to control the loudness as in a regular piano. The contacts are conductive rubber pills. After a lot of dis-assembly you can clean them with 99% isoprphyl alcohol and Q Tips. Clean both the pills and the circuit traces on the board they are pressed against. Be very careful of the ribbon cables between the halves of the case.
Posted on Jun 02, 2011
  • Jon Bruce
    Jon Bruce Nov 04, 2013
    Fred Yearian How do you dis assemble the keys to get to the contacts?
SOURCE:
How do you adjust casio px 300 when connected to ipad2
Newer Casio models that have "class compliant" USB interfaces such as the PX-330 would work (plug and play) since they now have "class compliant" drivers.
Unfortunately PX-300 is an older model that would need specific drivers and Casio only made drivers for Windows PCs.
May 01, 2014 | Casio Privia Px330 Px-330 88 Key Digital...
How do you connect a casio privia px 330 usb to ipad 2
Casio don't supply PX330 drivers for IPAD.
Get a Windows 8.1 tablet or connect PX330 to a desktop PC and use IPAD to Remote control that PC.
Apr 27, 2014 | Casio Privia Px330 Px-330 88 Key Digital...
How can I do an internal factory reset for my Privia PX-130?
Turn the Keyboard off the press and while holding down the [TONE] AND [FUNCTION] buttons power on the keyboard. Wait until all reset is done.
Aug 22, 2013 | Casio Privia Px330 Px-330 88 Key Digital...
Does the casio AD A12150LW MAINS ADAPTOR HAVE A FUSE INSIDE
No - the fuse is inside the keyboard. Or at least it should be. On your particular model have a look on the underside of the keyboard (where your knees go).
May 27, 2013 | Casio Privia Px330 Px-330 88 Key Digital...
Pitch drifts px 330
If anyone using a wireless guitar setup is close to it when playing, can do that.
Mar 19, 2013 | Casio Privia Px330 Px-330 88 Key Digital...
My Casio Privia PX-330BK Keyboard won't turn on.
Try checking your power cord. Perhaps someone stepped on it and it pulled out. It happened to me once. I thought something was terribly wrong with it. I was pretty embarrassed to find out that I'd just cut off power via cable... check your cords before worrying too much. If nothing seems to be wrong, take it in to the repair shop.
Sep 12, 2012 | Casio Privia Px330 Px-330 88 Key Digital...
Casio px-330bk keys pitch sharp top half of keyboard
The problem you're encountering is actually a feature, called stretch tuning. While real pianos are tuned in this way it's meant to sympathise with their natural 'organics' and might sound wrong on a digital instrument. The solution is to turn stretch tuning off. The manual should be able to tell you how.
Jun 15, 2012 | Casio Privia Px330 Px-330 88 Key Digital...
I just got a 18 month old privia px130 and when I play the G keys (middle and -1) and the -1C there is a hissing sound. If it only happens in the electric piano setting. If I set it on duet, it happens...
First thing is to verify if the sound is there using headphones. This is important test as it isolates problems in power amps and other connected equipment that may be sensitive to the particular pitch of those keys. If it is in the headphones, then likely you will have to take it to a repair shop as the problem would be very deep in the unit's sound generator hardware.
Jul 25, 2011 | Casio Privia Px-130 Px130 88 Key Digital...
I've recently purchased a Roland foot pedal for my casio privia px-300 keyboard. When playing a note, even though the pedal is not pressed, the note sustains. When I press the foot pedal down, it cuts...
Sorry, but Roland uses the opposite sense switch. They use normally closed where Casio requires normally open contacts. SOMETIMES one can rewire the pedal internally, but you have to be mechanically and electrically inclined to do that.
Jun 04, 2011 | Casio Privia Keyboard Case
Casio Privia Px330 Px-330 88 Key Digital Piano New Logo
630 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
