Pretty much every computer built within the last 5 years has built on network interface. However, to answer your question completely - look at the back of the computer where the network cable plugs in? Is it clustered around the video/sound, power, printer, usb, etc (integrated in); or is it located elsewhere (perhaps in the series of long narrow rectangular openings openings where the expansion cards go - separate).
Hope this helps.
It is integrated. Integrated 3C920-based 10/100 3Com® Ethernet controller. If you need drivers CLICK HERE to go to page then select support. This page shows your computer specs, support will take you to drivers. If for some reason your ethernet is not functioning you can always add an ethernet, or lan pci expansion card to your computer and use that. Almost any will do and you can get them for about $5.
