The most common cause of the gun not firing is loading it with the wrong staples. Look at the packaging for the staples and see if it lists the gun. Staples are NOT universal and are make for specific staple guns.
It "sounds like" it is jammed. You may have to pull out the staple with needle nosed pliers. e`1
Staple gun are simple device and the 'shooting' mechanism is just a sring loaded bar that hammers the staple out: the problem is usually a jam/stuck staple where the staple in the orifice where the staple comes out. Just use a small screwdriver and /or plier to remove the stuck staple which could be jammed against the hammer bar. You may need to force the hammer bar backwards with the help of your small flat head screwdriver.
Staple guns can use a variety of staples; the width of the staple is fixed, the lengths vary from 1/4" up (usually in 1/8" increments). You don't need to adjust the staple gun for the different lengths, just be sure the width fits your gun since some manufacturers have used brand-specific staples.
There are also a variety of staple types; there are staples for ceiling tile, electric wire, window screening, etc. My favorite staples for wood have the tips cut on a sharp angle, they penetrate wood well. Some staple types require a particular gun, I have a gun that shoots only round-top staples for small cables like phone & thermostat wire.
Make sure the staples you are using are compatable with your gun they should be type 53 or JT21 staples and they are not longer tham the gun is capable of taking I think the maximum capacity for this gun is 5/16 or 8mm.
Turn the gun upside down and pull back the carriage, the staples are laid in the empty chamber in the gun itself not on the carriage points facing in the direction they fire ie points facing you .
Push back the carriage this should slide over the strip of staples until the carriage clicks shut.
You should now be ready to fire, try and keep pressure down on the gun as the recoil can make the gun bounce and you will leave the staples proud.
Hope this helps.
You have too many staples in the gun. Chances are it was not shooting staples so you put more in. (Only holds 1 strip as if new from box) Check for a jam. Sometimes this keeps more staples from advancing.
Please rate
its problem is too much oil or not enough. never the less, it needs taken apart and cleaned and inspected. make sure you are shooting the right guage and brand hardware. generic doesnt always work.
Know the types of staple guns available. They can be manual, electric, battery operated or run by compressed air with an air compressor. Some staple guns have guide wires because they’re used by electricians that can’t pierce wires. Others have long noses to work well in corners and tight spaces. There’s also a reverse built ergonomic staple gun called a "forward action" because the handle and the staple’s exit point are on the same end of the staple gun. Some staple guns can shoot brads instead of staples. Know how each type of staple gun works. This one is so simple because it works just like a stapler. You press and hold the silver latch on the back of the stapler to open the body. Take the tray out and fill it with staples. Then it’s ready to use. Just put the staple ejecting end on your piece to be stapled and squeeze it. There is also the forward action manual gun which is used by pushing the handle down, too. The handle is just located near the staple ejection site. Use an electric staple gun for effortless stapling. There’s no need to squeeze or apply any pressure on these guns. They come with a very short cord so you will always need to have an extension cord with your staple gun. You can also go with a rechargeable battery operated cordless staple gun. They are great but they do run out of steam so for long use one with a cord is better. They’re also pretty easy on the wallet these days, so there’s no reason to go without this in your home tool kit as it’s something that does a lot of jobs. Know the versatility of the staple gun. Whether you have a manual or an electric model, these are some of the most versatile tools out there. You can use them to recover furniture, to build a birdhouse, to staple lattice to a patio, to build lightweight projects like a small knick knack shelf and to do wiring work.
