SOURCE: Problem with my Navman s50
hmmm..sounds like you are suffering from a firmware issue..have you downloaded any updates recently?
SOURCE: Navman S50 wont load maps
Ok i have had this problem on a S80 and have fixed it, and i went through a $h!t fight to get the navdesk 2008 software but i have it if anyone needs it and i loaded my navman up again, it seems to be working fine.
Step #1) Back up entire data from navman onto a disc or hard drive.
Step #2) Format the navmans internal memory and then cancel the format about 5 seconds into it, but less then half way.
Step #3) Install navdesk 2008
Step #4) under the tools tab, select the recover keys options.
Step #5) under the tools tab, select the reinstall navman software option, it will ask you to back up but as there should be nothing to back up it doesnt matter, and then it should reinstall the navman software into the nav man.
Step #6) Install the maps that are unlocked or the maps you want(you may have to buy maps that were not a standard map when your navman was brought.
Theres so many wonderfull things you can do with these navmans aswell as GPS, like watch video and play music belive it or not.
Thanks for reading i hope this helps someone.
DoMikSun
SOURCE: I have navman S30 and
All you have to do is load up the NavDesk 2008 sofware which comes with the CD, delete all the maps on your Navman, and reload it back into it from the CD. Problem fixed !!
