My Compaq 7500 CRT monitor shuting on and off repeatedly with a ticking sound every time(most probably the relay switching). The front panel LED is also flashing on and off along with it. Please help
You can remove the back panel and use an air jet to clean up the PCB and make it clean. The reason why the standard marking is made not to open is to prevent any accident due to carelesnes or inexperiecned handling.
But do not use brush on the components as it might change settings without your kowledge.
there should be a default setting in under the menu (on the monitor itself) browse though the menus using the up and down again, look for that defaults option and select it, most monitors have this.
hope that helps. use the thumbs if it does.
