Most of the time is the ice maker itself that is defective. inside ice maker is an small circuit board that freezes up, if you take ice maker out and leave it overnight out to melt any ice inside the board it may work after that.
This is due to the arm that controls the switch on the icemaker itself either being shorted or froozen in the toggled position. Usually the arm would lift as your ice container becomes full and shut the icemaker off until it reached a level where the switch would then toggle to the make ice position and then start makeing ice again. There are three 1/4" screws that hold the icemaker in place remove these screws unplug the icemaker and then use hot water to dethaw your ice maker for about 2-4 minutes after wards dry the icemaker then try reinstalling the icemaker if the problem persists replace the icemaker itself. If you have any further questions message me back I await your reply. Thank you Rick
Pour about 1/2 cup of water into icemaker . If it dumps , replace the water valve . If doesn't dump , replace the icemaker . Also make sure the coils are clean of dust , lint , etc...
The quick answer is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board.
If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker.
You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Post back if you need instructions on reparing it.
