Question about Casio FX570MS Scientific Calculator
How can I calculate x to the power n. I know that x to the power 2 and x to the power 3 buttons are given on the calculator but dont know how to calculate x to the power n. e.g. 5 to the power 8
  • 4 Answers
Yype in x, then press the button on the top full row that is the fourth from the left. (It should look like a right angle facing up) Then type in n.
Posted on Jun 01, 2011
Testimonial: "Thank you so much. I bought this calculator just for an exam (starting tomorrow) and the instruction booklet didnt have this info. Thank you!!"
SOURCE:
Where is the 'comp' button on the hp calculator
There isn't one. Unlike calculators from other makers, your HP knows when you've made a data entry and when you haven't. Simply press the item which you want. For example, if a book tells you to press COMP then PMT to calculate the payment, simply press PMT.
Feb 19, 2014 | HP 10BII Scientific Calculator
I want to calculate powers on my calculator but am unsure what buttons to press
You have two buttons to calculate powers: The [x^2] calculates the square of a number while the [caret ^] key allows you to calculate any power, be it with integer, fraction or negative exponent.
Both keys are next to one another, one below OPTN and the other below the VARS key.
To calculate roots, you have the square root [SHIFT][x^2] the xroot key [SHIFT] [caret ^] , the CUBE root [SHIFT] [(] , and the inverse key [SHIFT][).
Feb 28, 2011 | Casio FX9750GII Graphic Calculator
I dont know where the power of ten button is, it is really confusing, when you dont know where it is when doing equations on your homework.
To enter an exponent of ten, use the EXP key in the middle of the bottom row. For example, to enter 1.2 times 10 to the 7th, press
1 . 2 EXP 7
If you want to raise 10 to a value, use 10^x, the shifted function of the LOG key on the top row.
Oct 19, 2010 | Casio FX-260 Calculator
Exponents
Hi a ritha,
If you are talking about the FX-300MS calculator, the ^ button should be there just below the large "Replay" button, on the immediate next row, slightly to the right. After pressing that, write "-2" withing brackets, like this (-2). The * function is in the number pad below, as you know. If your calculator really doesn't have the ^ button below the Replay button, it is probably faulty. Go exchange it for a new one.
Mar 28, 2010 | Casio FX-300MS Calculator
I dont know how to find the standard deviation, I have been given a list but I dont know how to compute them into the calculator
You can use the stdDev( function found on the LIST MATH menu. Press 2ND LIST Left-arrow to get to that menu.
Jul 16, 2009 | Texas Instruments TI-84 Plus Silver...
I need help with this casio caculator
If you mean to do x power y, so you must have an ^ button or y with little x(top right) this is the power. And when you want negative power like -2 so input 2 then "+/-" button (it's change the sign of the number).
Jul 06, 2009 | Casio FX-115ES Scientific Calculator
Exponents
There is no such key, only powers 2 and 3 are given a specific key. To raise a number to any power (including 2 and 3) you use the general power key [^] or [X to the y] or [Y to the x] I do not have the calculator with me.
2 to the power of 20 is entered as 2[^]20 =1048576 ( If these were bytes , this number would be called 1 megabyte.
Hope it helps.
Apr 07, 2009 | Casio FX-115MS Plus Calculator
I cant figure out how to put exponents in to my calculator
For 5 to the 6th power, type
5 ^ 6 =
You should get 15625
Mar 24, 2009 | Casio FX-300W Plus Calculator
When I divide answers are always given in Fractions. Can I change it to come out in decimals?
To change from Fraction display to Decimal display on the Casio fx-300ES (and probably other calculators)
1) Press the "SHIFT" button
2) Press the "MODE/SETUP" button
3) Press the "2" button
This Changes it to LINEIO (Decimal)
Doing all of the above but pressing the "1" button instead of the "2" puts it back into MATHIO mode (Fraction)
Hope this Helps
(SHIFT)(MODE/SETUP)(2) to change to decimal
Nov 07, 2008 | Casio fx-300ES Calculator
Casio FX570MS Scientific Calculator Logo
185 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
