To find out what the problem is try this, swap over the right and left leads from the deck to the amp. If the problem stays on the left channel there's something wrong with pre-amp in your amp. If it goes to the other channel (right dead) it's the deck. Next remove the wires to the cartridge to the deck with the fault. Make a note of how they fit on the cartridge before you do. With the amp connected to the deck and on. Touch (one at a time) each of the four wires with your finger. Two of them will probably produce no sound. But from one wire you should hear a buzz on the left channel and from another wire a buzz on the Right channel. If you get a Buzz on the left speaker then all the connects are good and the cartridge has gone. If you don't get a buzz, then there is something wrong with the left cable connector between the deck and amp.
