Mobile phone
hey. i think this is how to do recovery mode!!
When you reach to that part here's what you should do:
1. Don't disconnect the USB cable from your PC but disconnect your phone from the USB cable.
2. Turn off your K750i and wait for at least 20 seconds after you turn it off
3. Press and Hold "c" in your K750i and while holding the "c", connect your K750i back to the USB cable
4. It is not suppose to turn on but it will start the Update
5. Once the the Update starts you can release the "c".
Note: I hold the "c" a bit longer because I want to make sure that the update will start properly
Tip1: While pressing the "c" and connecting back your K750i to the USB
cable, if your K750i turn on it means that you haven't updated the USB
Driver for update. You only install the USB Driver for data transfer
support
Tip2: USB Driver for your firmware update is only 2 files inside the
zip. Extract the file on desktop so that when it is necessary for you
to install you can find it immediately
sorry i cant add much detail, i used to have a Sony Ericsson, but it go stolen, so im now using nokia, an i never have used recovery mode!
hope this helps!!
In the end it turned out to be the wrong screen I'd been sent. I needed a new screen with an orange -coloured connector. When one with the orange-coloured connector was fitted, the screen was fixed and I was able to view 100% of it as I had been able to before I'd dropped the phone.
