I can put automatic keypad lock but i want to use a numeric keypad lock code. everytime i unlock the phone, v must enter the lock code for using the phone. how to do this on sony naite phone?
thanks in advance...
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
Many people like the Samsung Intensity because of its slide-out QWERTY keyboard. However, one drawback to the phone for some users is that, unlike a flip phone, the numeric keypad is always exposed. When the Intensity is kept in a pocket or purse, this can result in accidental phone calls, multiple all-black pictures, and sudden activation of the voice command feature.
Luckily, you can lock the phone's keypad to keep it from engaging any functions when you're not using it. Locking the keypad is easy. Just hold down the 0 (zero) button for about two seconds, and a message will pop up telling you that the keypad has been locked. While it's locked, you won't be able to use the numeric keypad.
The standard way to unlock the phone is to press the upper right options button (the one that you would typically press to bring up your Contacts list) and then press the center OK button. (You will see prompts for both of these buttons when the phone is locked.)
However, there is also a quicker way to unlock the phone -- just slide the keyboard open. Sliding the keyboard open will unlock your numeric keypad immediately, and even when you close the keyboard the phone will remain unlocked. If you want to lock it again, you'll have to hold down the zero button to re-lock it.
You can also enable Auto Key Lock mode, in case you think you'll forget to lock your phone. With Auto Key Lock mode turned on, your phone will automatically lock itself when it's not in use and the backlight goes off. You can turn Auto Key Lock mode on or off from the Phone Settings menu.
just go to "menu" and open "settings" select general then "security" then open "phone and sim card" and select "phone auto lock period " select "user define" enter the minutes and enter the lock code of your mobile and you are done. after the selected minute phone will be automatically locked with code
Keypad lock To prevent accidental key presses,
select Menu,
and press * within 3.5 seconds to lock the keypad. To unlock the keypad, select Unlock, and press * within 1.5 seconds. If the security keyguard is on, enter the
security code when requested. To set the keypad to lock
automatically after a preset time when the phone is in the standby mode, select Menu >
Settings > Phone > Automatic
keyguard > On. To answer a call when the keypad is
locked, press the call key. When you end or reject the call, the keypad locks
automatically. When the device or keypad is locked,
calls may be possible to the official emergency number programmed into your device.
First, activate the Automatic Keyguard which locks the phone keypad after a time that you set:
Menu>Settings>Phone>Automatic Keyguard>On
Then set the Security Keyguard which will demand a code to unlock the phone:
Menu>Settings>Phone>Security Keyguard>On
Finally, your lock code is 12345 as standard. If you want to use the lock for security, you need to change the code to a personal code:
Menu>Settings>Security>Access codes>Change security code - then you need to enter the current code (12345) then enter your chosen code twice.
Each time you need to unlock the phone, you'll need your personal code. Be sure not to forget the code, as if you do you will have to get the phone reflashed at a Nokia service point which will wipe your personal data from the phone.
1.5 seconds. If Security keyguard is set to on, enter
the security code if requested.
To answer a call when the keypad is locked, press the
automatically locks
Enter the permanent factory remote keyless entry (RKE) keypad code.
Press the 1/2 button within 5 seconds to activate the programming mode associated with the memory position 1 settings. Holding the 1/2 button for more than 2 seconds after activation erases the stored personal code.
Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 1 settings. Entering any new personal code automatically erases the old personal code.
Press the 3/4 button within 5 seconds to activate the programming mode associated with the memory position 2 settings. Holding the 3/4 button for more than 2 seconds after activation erases the stored personal code.
Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 2 settings. Entering any new personal code automatically erases the old personal code.
Press the 5/6, 7/8, 9/0, 7/8 and 9/0 button within 5 seconds to activate the programming mode or allow the system to timeout.
Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed. Entering any new personal code automatically erases the old personal code.
You can lock your phone manually or set the phone to lock automatically whenever you turn it off. To use a locked phone, you must enter the unlock code. A locked phone still rings or vibrates for incoming calls or messages, but you must unlock it to answer. You can make emergency calls on your phone even when it is locked (see page 68). Locking Your Phone Manually
Find the Feature > Settings > Security > Phone Lock > Lock Now
Unlocking Your Phone Tip: Your phone’s unlock code is originally set to 1234. Your service provider may reset the unlock code to the last 4 digits of your phone number.
Setting Your Phone to Lock Automatically You can set your phone to lock every time you turn it off:
Find the Feature M> Settings > Security > Phone Lock > Automatic Lock > On
If You Forget a Code, PIN, or Password Note: Your phone’s 4-digit unlock code is originally set to 1234, and the 6-digit security code is originally set to 000000. Your service provider may reset the unlock code to the last 4 digits of your phone number before you receive your phone. Press To 1 keypad keys enter your unlock code 2 OK (+) unlock your phone Find the Feature > Settings > Security > Phone Lock
Master Clear Clear all user settings and entries except SIM card information, erase all downloaded pictures and sound files, reset all options except unlock code, security code, and lifetime timer: M > Settings > Initial Setup > Master Clear Caution: Master clear erases all user-entered information (including phonebook and datebook entries) and user-downloaded content (including photos and sounds) stored in your phone’s memory. After you erase the information, you cannot recover it.
first, take out the battery and press the RED end call key for 15 seconds, then put the battery back in and turn on the phone.
if that doesn't work then try this from the website.
How do I lock/unlock the phone's keypad?
To lock and unlock your phone's keypad, press and hold the left navigation key.
Or, select Menu -> Settings -> Keyguard. Then highlight either of the options and press the OK
button. You can set your phone to lock the keypad immediately, or
automatically if no key is pressed after 30 seconds, 1 minute, or 5
minutes.
