Refrigerators Logo
Posted on Jun 01, 2011
How do I remove the plastic drip tray from behind my Wesitnghouse Aurora Fridge Freezer.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 28, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2059
Points
We had a really bad smell coming from the back of our westinghouse aurora. and yes found it to be emanating from drip tray at the back. To remove this we had to undo 4 clips at the base of black motor thingy, that the plastic drip box sits on. Then we were able to lift whole thing a bit ,(10mm up and 50mm out, approx) so we could tilt everything forward and sweeze and wiggle tray out. then cleaned with bleach. also we unblocked hole inside fridge that allows water to drip into drip tray at back.
Anonymous
Level 1:
  • Posted on Jun 27, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2059
Points
0
His model Westinghouse Aurora Fridge Freezer 500 litre....has it got a sensor for the ice unit that gives command to the time machanism defrost?????
Igloo mini fridges
The question is: Are you seeing water inside the fridge where it shouldn't be? Are there water stains in the try? Some of these have no tube, the water just drips from a small hole above the tray.
Freezer not freezing
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Fridgidaire freezer warming up
Sep 09, 2013 • Freezers
Freezer compressor is short cycling
Warning light
1helpful
I keep getting water at the bottom of the fridge, under salad boxes on my Hotpoint fridge
2answers
Fridge won't cool below 60, freezer won't go above 20
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
1helpful
Water leaking
the bottom tray/salad compartment will always get a fair amount of condensation because they are glossy plastic(bathroom paint is matt)the only "cure" is kitchen towel under the tray and remove once a week.as for the drain it is normally at the back and does collect a fair amount of "moss"in the tube,pour some clorine bleach down to clear any out.the design of the shelves directs the side/back condensation down the drain.
1helpful
Have an 8yr old Kenmore top freezer. Water is dripping from top of refrigerator section,from back right side of a vent. Have made sure food is not blocking circulation in freezer. Help!
Your freezer has a drain tube located behind the: freezer ice tray back rear plastic cover; It leads to the defrost tray at the bottom of the refrigerator. remove the back rear plastic cover, the drain will be located at the right side of the coils.
flush the tube out using a funnel and, a pan of hot water. empty the floor defrost tray as you do this.
Top Westinghouse Refrigerators Experts
vince
john h
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
