Kingston 1 GB microSD Card with USB 20 microSD Card Reader FCRMRB+SDC1GBKR (Black) Drive Case Logo
Posted on Jun 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Forgotten password of micro sd card? how to reset its password
Brian Sullivan
Level 3:
  • Kingston Master 27,725 Answers
  • Posted on Nov 12, 2013
Brian Sullivan
Kingston Master
Level 3:
Answers
27725
Questions
Helped
5669533
Points
79191
Micro Secure Digital memory cards, or Micro SD cards, provide storage for a variety of different kinds of devices, including mobile phones, PDAs and cameras.
They can be protected by passwords so that the information that you have saved on it is secure. Sometimes, the password can be forgotten or lost.
Recovering your password is easily done with your computer and SD card reader on your computer.
Place the micro SD card into your card reader on your computer.
Right-click your "Start" button and then "Explore".
Find the micro SD card, it will be listed as a removable drive.
Click on the micro SD card and the files will show on the right-hand side.
Find the file that says " MMCSTORE" and then select "Copy."
Right-click on your desktop and then click "Paste."
This will move the MMCSTORE file to the desktop so that you can get access to edit it.
Right-click on the MMCSTORE and then click on "Open With." Open the file with Notepad.
Read the text to find the password. It will be in plain text.
Remove the SD card from the computer and place it into the device for which it is used as storage. Turn on the device.
When it prompts you for the password, enter it.
Micro sd memory card password remover
Turn on the device.
Forgotten memory card password
final thing is format memorry card and try to recovery files
How to unlock micro sd
Micro Secure Digital memory cards, or Micro SD cards, provide storage for a variety of different kinds of devices, including mobile phones, PDAs and cameras. They can be protected by passwords so that the information that you have saved on it is secure. Sometimes, the password can be forgotten or lost. Recovering your password is easily done with your computer and SD card reader on your computer.
Place the micro SD card into your card reader on your computer. Right-click your "Start" button and then "Explore". Find the micro SD card, it will be listed as a removable drive. Click on the micro SD card and the files will show on the right-hand side. Find the file that says " MMCSTORE" and then select "Copy." Right-click on your desktop and then click "Paste." This will move the MMCSTORE file to the desktop so that you can get access to edit it. Right-click on the MMCSTORE and then click on "Open With." Open the file with Notepad. Read the text to find the password. It will be in plain text. Remove the SD card from the computer and place it into the device for which it is used as storage. Turn on the device. When it prompts you for the password, enter it. Hope this helps.
7helpful
2answers
I have locked my memory card and forgotten the password. Format card also requires password and my laptop cannot read it. Please help.
All you have to do is:
Step One:
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process of removing the micro SD password
Step Two:
The first alternative - use the software HP Drive Key Boot Utility
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Unlocking micro sd memory card
Hi..
please follow the instruction in this tip you can retrive the passward for your micro sd card
http://www.fixya.com/support/r5357099-retriving_memory_card_password
Thanx
3helpful
I forgot my password of my memory card. Now how i can unlock it
Please have the instructions to the forgotten password of your
Micro SD Memory Card within the below FAQ article:
http://en.kioskea.net/faq/sujet-4154-micro-sd-card-lost-password
Please post your feedback and Vote if the problem resolved as per your satisfaction.
2helpful
2answers
Micro sd memory card for 3110c password protected was forgotten
connect ur memory card, to the comp. through card reader,, then format it,,, lock will be opend
Can't format my kingston micro sd memory card
you may do not have administrative rights to format [or it may be password protected]
1helpful
Micro sd password onlock
take it to a mobile center and ahve them use the JAF box to master reset the code or remove it permanently for you.
Micro sd card
how did u lock it? with an application? you can simply format it or try using the utility to recover the password.... you might be in trouble also it might not be a password try simply sliding the swich on the adapter card or the micro not sure if yours has a lock slider..... can you still see the files on the card?
Top Kingston Computers & Internet Experts
Jean Thiebaux
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
