Probably not door switch, but to access, remove door gasketf rom cabinet in area of door switch and door switch is only held by 2 screws. more likely to be the suppressor capacitor. remove top and look at suppressor - they sometimes go pop
Hotpoint red led flashes Washing Machines Questions ...
www.fixya.com > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
hi if you are getting no power at all and fuse in plug good i would check interlock that is were door locks in next is control panel usually interlock is cause
Problem seems to have corrected itself! I tried another slow spin cycle, waited a reasonable interval for the Door Locked light to go off, then when it didn't I switched the power to the machine off. I tried squeezing the door catch a few times and pressing the door downwards, then left it. Some time later when I went into the kitchen the door was open. I washed a small load this morning and the machine worked normally. Fingers crossed, it's ok now.
Mains filter at top right - Check for live and Neutral Presence.
ON/OFF Switch - Check for Power in and Out when switched on.
Door Lock - Check for Power down 1 wire and when Locked, Power ( Live ) present in 2 wires. The third wire is the Neutral for the door locking circuit. Check this Neutral is OK. - Let me know.
did you check the plug top fuse? Try plugging a reading lamp in to check you have power. If you have, suspect the on/off switch or the door interlock micro switch, or a burned out wire to either
This sounds like the min bearings have gone, open the door and see if there is any play up and down on the drum. if so its the bearing if not it could be something that has fallen from a pocket and got stuck between the metal clothes drum and the oute drum casing. a take apart job i am afraid for both issues.
