About the only way to do that is with a multimeter, preferably digital. Touch the probes onto the contacts and if the red probe is on the positive terminal, the reading will be a straight reading, eg. 18.6v. If the black probe is on the positive your reading will be a minus (negative) reading. eg, -18.6v. If you are using an analogue meter, you have to be quick or you will damage the instrument. If the red probe is on the positive terminal you will get a reading. If the black probe is on the positive reading the needle will go of scale below the zero point. Use a high voltage setting to minimise the input to the meter.
