SOURCE: Linksys wireless-G 2.4 GHz broadband Router
If the default ip address has been changed, reset the unit. Reset is on the back small button or pin hole. Plug the cat5 cable into the router and your network card on your pc, then log back in using default 192.168.1.1 no user name, password is admin.
Link to linksys troubleshooting wizard.
SOURCE: I don't know the password of my Linksys router.
Hold teh reset button in the back for 30 seconds and it'll reset the router to factory defaults. From there, open a browser and type the address 192.168.1.1. Username is blank and password is "admin". If that doesn't work, many of the newer linksys routers have "admin" as both the username and the password.
SOURCE: Linksys WRT54G won't open ports
What modem are you using? Who is your DSL provider? The reason why you need to consider this is because it could be that the modem's setting is not on a bridge mode or is not set to have the all the ports to be open.
So even if you have your router set to have all the ports open but your modem is not then it can cause conflicts. The transmission of the data stops at the modem.
SOURCE: I have a netgear ds116 hub and i want to set up a linksys router
Here's what you can do. Don't connect the Linksys router yet to the hub. Connect 1 computer directly to the Linksys router. Access the router's setup page of the Linksys router thru http://192.168.1.1
It will prompt you for username and password. No username and password is admin.
Look for Local IP Address or LAN IP Address. Change the LAN or Local IP Address of the Linksys router to 192.168.5.1 then click on Save Settings at the bottom. Right after saving the settings, unplug the power of the Linksys router, connect it to the hub and it should be good to go.
SOURCE: I am unable to set up my Linksys WRT150N router security
Is there any computer connected to the router ?
If not then you will need to connect the computer
to the router.
Do not change any wireless settings on the router
with the wireless computer.
you will need to connect the computer to the
router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the
router.
Now once you change the network anme and security
on the router, you will need to connect to the
wireless network on your wireless computers.
Click Here for step by step instructions
