yes, we have like 1000000000 posts here, LT does not start.
endless it is.... and few come backs, to show whats up.
its always the same reasons, short list.
Ok, not on time did you say the word BIOS>
did you know BIOS works with HDD/SSD removed
forget the OS for now,
if the BIOS ok called up the screen is ok
if not, then its a catastrophic failure.
you can even boot it with external, screens, 15pin pin VGA.
if not its DEAD if BIOS IS DEAD, that is a clear 100% dead
with battery out.,
so the power pack is bad.
ever consider that, i keep them as spares, so if on say vacation
mine blows out, i have a backup.
with a good power pack
the MOBO will work
and will beep if you remove RAM.
with special beeps, beeps are BIOS code running,...
if it cant beep the MOBO is toasted.
I uses a voltmeter on the rear of the power jack
19vdc is spec (the pack side tells you that in clear text)
ok its got power. (even with power button pushed)
ok power good, push power botton
and i must get beeps BIOS
one or the other, even with
here are the LED flash codes on my hp 8540.
hp.com has yours too, if you RTM ,read the service manual. for free
nice how fixya wrecks photos. sad
the blinks mean,
gpu dead
bios dead
cpu dead
ram dead
and more, this laptop dont beep it only blinks
so you must read the book to learn what YOURS does.
