older post 1month
you failed to say what tires are touching, dry pavement or ice/snow or off road...... MATTERS big time.......!
the operators guide tells you not to do that.
the rules for 4Hi and low are different. RTM? yet?
last year ZJ
Quadra-Trac(tm) NV242 box. it is. full and part time box.
what does it (oper guide)tell you.
stay out of part time on dry roads. (clear?)
rule 2, save rule for Low Range.
low range is not full time 4wd.
if you fail to believe it , it will wind up and go crunch
here is the direct quote.... see last line,,, its 100% real.
i you had the NV231 box, all gears are Part time, all 4wd gears stay off dry pavement.
