How do you set up Netflix on TV? Connect your Internet-ready television either with an Ethernet cable or wirelessly to your router. Follow the steps on the television to connect it wirelessly. 2. Select theNetflix Apply from the menu on the television screen.
Your tv needs to have a connection to the internet. If the tv does not have it, you can use a peripheral like a game system that has internet access. A lot of newer tv's have internet access with direct links to Netflix and other online viewing providers. You can also hook up a computer to your tv with a cable and mirror or extend the display to the tv. Then connect to Netflix through your computer.
Netflix should already be available on the Wii, you just need an internet connection or wifi to the wii, and an active netflix account, then follow the instructions and use your computer to go to netflix to update your home viewing equipment (ie activating your wii on the account).
Hi, NETFLIX is an ONLINE service, the things your t.v. would need is an INTERNET connection, or a connection for P.C. ( also may be called V.G.A or D.V.I. ) If your t.v. has an internet connection it will be called a L.A.N. or W.A.N. connection ( it'll resemble a telephone jack ) hook this up to your internet. The easiest way however is to play NETFLIX through your P.C./laptop then view through the external monitor feature of computer. So unless you have a very simplified setup it should be possible to not buy extra equipment for NETFLIX. Good luck, and I hope this helped, Prodzilla
The Vizio does not have Internet capabilities. You need to hook up a computer via the VGA or HDMI port. Then youor computer controls what you do with the intenet.
I assume you have your PS3 connected to the television and you can play games. For Netflix, you need to plug in an ethernet cable to the back of your PS3, be a Netflix member with at least a $9 monthly unlimited plan, and get a Netflix "Instant Streaming Disk" for PS3, which you can get for free (go to the account page and type "PS3" into the help box) once you are a member.
