SOURCE: turn the ringer off
To turn off the ringer on my Vtech cordless phones, I have had to turn off the base ringer & all handsets.
Base Ringer:
Press Menu and listen carefully, continue to press menu until you hear "Base Ringer, to change base ringer press change", hit change and it will say "Off", then you must hit the PLAY/STOP button to save your change.
Handset:
Press the program button and use your "up/down" key to cycle until you see the Ringer selection. Press SELECT and then use your "up/down" key(s) to cycle until the OFF selection is see on the handset screen. Press select.
SOURCE: ringer off
The VT-9118 can use one of 4 different ring tones, and can be turned off.
To reset your ring tone:
To turn the ringer off, follow the same instructions, but choose number 5.
Hope this helps you. If you need for information, you can download the user manual from http://www.vtechphones.com/docMgt/public/art/313/vt9118.pdf
SOURCE: my vtech cordless phone will not ring. message is ringer off. how to turn ringer on.
I believe you can navigate through the menu and when you get to the ringer part push up on the navigation arrow. That should work. Thanks for using Fixya.Com.........Enjoy your evening!
