Sony VAIO VGN-NW150J/S Notebook Logo
Posted on May 30, 2011
How do i replace my keyboard on Sony Vaio VGN-NW150J
Anonymous
Level 1:
  • Contributor 942 Answers
  • Posted on May 30, 2011
Anonymous
Contributor
Level 1:
Answers
942
Questions
0
Helped
209489
Points
57
You can call the SONY Technical support and give them the serial number of the laptop and they will immediately replace the keyboard.
1helpful
DARK SCREEN SONY VAIO VGN-NW150J
replace the inverter board it connects to the screen and, is usually at the top of the laptop under a panel between the screen hinges
I have a vaio nw150j with bad hard drive. What are the steps for ssd and new os install?
If you bought the same drive I don't see why you'd have to do anything to the Bios.
Vgn-nw150j keyboard Sony Vaio many keys stopped working all of a sudden need help?
Laptop keyboards do deteriorate from time to time. Once any key stops working, it is time for a replacement. Doing so is not difficult. Simply undo the case screws and gently separate the case to expose the keyboard. The keyboard floats inside and lays in the main board. Lift gently and pull out the small flat wire connection. The keyboard slides out and replace with a new board. Place flat cable in port on the main board, lay keyboard on top of chassis, close the top/bottom of case, tighten screws and all done. Go on line for Keyboards.
2answers
Hi, I have Sony Vaio, VGN-NW150J, I tried everythink but I cant install my camera, I don't know what is wron, please help me, I have Windows 7 Ultimate 64-bit and I was finding some solutions by the...
HI,
go to following link and click on Download now and get your webcam drivers.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNNW150J&upd_id=5051&os_id=49
Please don't forgot to rate if you get the solution.
Hi! I installed windows 7 on Sony VGN NW150J and my web camera does not working. Drivers from sony official site doesnt help. in device manager I see Base System Device which is unknown. help me,pleace....
Hey,
Make sure you are downloading the correct driver for your webcam, and make sure that if you are installing 64bit windows 7 that you have a 64bit driver, and same with 32bit (im sure you are, but double check just in case).
If you are 100% sure of that, have a look through the drivers page for your laptop and look for a "chipset" update of some sort.
Hope this helps :)
4helpful
2answers
My left mouse button on sony vaio vng-nw150j isn't working
Generally, if a mouse button quits working, it requires the replacement of the touchpad assembly.
Boot to the safe mode, see if the button works there, if it doesn't, then it is a failure of the switch in the button
http://cgi.ebay.com/TESTED-Sony-Vaio-VGN-NW150J-LCD-Keyboard-Palmrest_W0QQitemZ120522991092QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1c0fbae5f4#ht_1088wt_1165
How to replace keyboard on sony vaio VGN FW230J
This kind of replacement needs to be performed by qualified person. Better take it to the service.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
