My eyeclops mini projector will not show a picture. I have turned on my xbox (what I have it hooked up to) then turned on the eyeclops, I get audio but no picture. I thought maybe it has burned out, but I bought it new less than 6 months ago and have rarely used it.
If you've got the version with a DVI input, use a HDMI to DVI cable. That'll take care of picture but not sound. You need to hook up an audio cable that finishes in a 3.5mm stereo jack if you want to use the Benq's speaker.
If you have the older version with just a VGA input then buy an Xbox 360 VGA cable. You'll also need an audio adapter; 2x phono/RCA sockets going to 3.5mm stereo jack.
You do know the lamp won't light unless the projector has an input source connected?
It's not designed to be repaired because there are safety issues in case you put too bright a lamp in, after all it is a children's toy. That said you have 2 options, take out the old lamp, and identify it, that should be fairly easy, or contact the distributors. Contact JAKKS
I dont think it as solution. when power on, it has to show the VOX logo initially. Later we can set the i/p mode...
I had the problem with my new led vox projector. Larer I replaced it. now I got the same issue with the replaced product. Each time I used only 2 to 3 hrs the device. Waste of buying such brands.
If there is a port for computer audio (3.5mm jack) you can buy at converter for RCA stereo to headphone jack. These can be bought at mostly any radioshack. This is what you'd be looking for:
http://www.newegg.com/Product/Product.aspx?Item=N82E16812200418&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Cables-_-STARTECH-_-12200418
Your projector audio input is a stereo mini input. you will need to purchase a audio splitter. you will need a male stereo mini to two rca felmal. connect the stereo mini to your projector then the red to red and white to white rca.
unplug all rca cables from your eyeclops, then try all three colors one at a time, into the yellow colored hole on the side of your eyeclops, until you get a picture, and you have to have the dvd player on and playing a dvd, otherwise the light won't come on your projector, then plug in the audio sources, the yellow and white. When I got my eyeclops mini projector, it wouldn't work at all when I plugged the yellow rca cable in the yellow hole on the side of the eyeclops, the red into the red, and the white into white. Only when I placed the red rca cable into the yellow hole on the eyeclops, the yellow into the red hole, and the white rca cable into the white hole did it finally work. That was for my dvd player. With the video game function, I plugged each color Rca cable into their same colored holes on the eyeclops and it worked fine, but again, you have to have your device, whether it be a dvd player or game system on and running before your eyeclops led lights will turn on. Not sure I had to switch colors when I played my dvd player, but that's how it works on my mini projector, anyways.
