Question about Jacuzzi Garden
Jacuzzi pump s/n 91110890 model #1e112-8 date 24b95 looking for parts availability & or parts list having problem getting up to pressure it's a jet pump thanks
SOURCE:
jgwhomeequip
  • 1902 Answers
SOURCE: Jacuzzi jets not pumping out water
Check the jet pump, also where the filter is there are two 90s plastic. make sure that they are both in the water, if all those check out then check the switch for the jets. It sounds like the pump is bad and is not pumping the water. Even if the motor works and the internal parts of the motor seal gets wet then it all needs to be replaced and rebuilt. Very easy to do yourself. Like always be careful and unplug the unit.
Posted on Feb 11, 2009
  • 3 Answers
SOURCE: karcher k2400hh pressure washer, water pressure cuts out.
Hello cikanek:
Try this:
From your posting, I assume you have removed the splash cap and the nylon bypass valve cover. Connect the water supply to the pump and connect the high pressure hose and wand to the pump outlet. Wad up a small towel and place it over the bypass valve opening to catch the valve insert when it pops out. With the engine throttle closed, pull the starter cord several times to see it the valve insert will pop out. If it doesn't come out after two or three pulls, set the throttle to low and start the engine. I have performed this procedure a number of times and the valve insert always pops out. There is no real danger of the valve parts getting seriously airborn since the actual pump output volume is very low (2.5 Gal/min).
Good luck,
Ed
Posted on May 23, 2009
SOURCE: 5 year old Laars 25,000 LX won't ignite.
The low pressure indicator is for the gas pressure not the water pressure. The heater won't ignite because it's not getting gas to the igniter. Check gas supply, if okay, check gas connections, valves, etc.
The 1 HP motor should be fine on the jacuzzi.
Posted on May 26, 2009
boysor2933
  • 293 Answers
SOURCE: I have a Jacuzzi Jet Pump Model 7C-S/B. Not Working
Check the breaker that supplies power to the unit. If it is in tripped position, check if the motor is grounded ( continuity between terminals and motor body), check for shorted windings (infinity resistance value between the winding phases), and finally check if the pump is stuck up due to debris or defective motor or pump bearings.
Posted on Jun 11, 2009
  • 31 Answers
SOURCE: My American Standard whirlpool pump will only hum.
The bearings (or bushings) of the pump or pump motor have siezed, these can be replaced on some models but for the most part you will need to replace the pump and/or pump motor. and as where to get parts, i would suggest the outlet from wich you purchased the unit or another appliance outlet. Or if you feel up to the challenge, im sure you could find replacement parts on the internet: google, ebay, etc.
Posted on Sep 30, 2009
How do I replace the on/off switch on my jacuzzi pool pump
you might not be able to replace the switch parts might not be available jacuzzi is out of business you might be able to replace the motor if not get a new pump they can cross reference for you
Jul 28, 2014 | Jacuzzi Pool & Spa
Jacuzzi hot tub replacement jets
your local jacuzzi dealer should be able to source you some parts , but i can tell you if it's only a o-ring failure these are avail from your local hardware store , as most jets are rebuildable , some are not look at back for screws to see if they are or not
May 20, 2014 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
I have a jacuzzi amiga N890 that when you turn the unit on it just hmmms. It is getting power but does nothing else accept hmmm.
If you turn the Jacuzzi pump on and it just hums and no water flows through the jets then you have a bad pump.
You will need to get the brand name of the pump and the model number before you can begin your search to find the proper replacement.
Bath Pumps each have their own size. You will want to find the exact brand so you do not have to change any of the plumbing.
US Parts Center
Aug 20, 2013 | Jacuzzi Amiga Whirlpool JAC-N890...
I'm trying to find a seal kit for a Emerson spa pump Model #T55MWCCE-1208
The seals are specific to the Jacuzzi pump housing not to the Emerson motor. Most Jacuzzi pumps use the PS-200 or PS-201 seal (some have it listed as AS-20X) here is a Pump Seal Cross Reference.
Jul 25, 2012 | Emerson Pool & Spa
I need a motor end cover, where can I get one? Thank you!
Jacuzzi (Carvin) Magnum, Force & Plus pump parts are hard to find.
Here is a link to our site which has a parts explosion/diagram for those pumps.
Jacuzzi Magnum, Magnum Plus, and Magnum Force Pumps
Jun 08, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP 2 HP...
How to separate the two impeller flanges of a jacuzzi pump to access the impeller in order to remove the wet end from the motor OR is there some way to remove the wet end of a white JWB 60C Ser no. 06785...
That is an old sealed Jacuzzi pump that can not be repaired. It is one of many reasons why Jacuzzi never did well in the pump business and has gone from owner to owner over the years. Unfortunately your pump is not repairable without destroying it in the process.
Wet ends may still be available. The part numbers I have are:
850100 .5/.75 HP
9011000 1 HP
850200 1.5 HP
856600 2 HP
0199000 Gasket (2 req’d)
4516000 Flange, 2”
Good luck,
John
Aug 22, 2010 | Jacuzzi Impeller, L - 3/4 H.P
Need to order a replacement toilet seat for Model Jacuzzi Era toilet. We have looked at Lowe's and other home improvement stores and all the available elongated replacement toilet seats do not seem to be...
Try checking plumbing supply houses instead of home improvement stores. Im not sure where you are located. Here in MO. I use Harry Cooper Supply or Riback Supply or Southern Materials. A good supply house should be able to help you find what you are looking for. Hope this helps.
May 04, 2010 | Jacuzzi BK37959 White Era?? Two-Piece...
Jacuzzi pump not pumping
I would probably say that the pump is clogged up or frozen. The motor humms until the heat sensor clicks it off. Try taking apart the front of pump and see if it turns and you should see the problem. Parts are available at most pool stores. Pumps are usually cheaper online.
Jun 25, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Jacuzzi Magnum Force Pump not working
The number one problem is air leaks.......check all connections to see that they are tight, and rubber seals. The intake side would give you trouble with air leaks. If you dont find any leaks then I would pull the pump cover and check the impellor. Pool stores have parts and lots of knowledge.
Jun 09, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Garden Logo
107 people viewed this question
Top Jacuzzi Garden Experts
john h
Bath and Spa Parts...
Jay Finke
Jay Finke
Are you a Jacuzzi Garden Expert? Answer questions, earn points and help others
