Mitsubishi WS-55511 55" Rear Projection Television Logo
Posted on Aug 16, 2008
Mitsubishi ws-55511 any luck solving your tv problem? or did you have a repairman fix it? Please contact me Thanks, Lou
Anonymous
Level 1:
Problem Solver:
  • Contributor 2 Answers
  • Posted on Aug 18, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
478
Points
I sent it out for repair. $700 bucks total, but now the color is bad and the HD isn't set properly. They'll be coming back out this week sometime to fix both.
2answers
We have a rear projection Mitsubishi TV, Model # WS-55511.We had a power outage last night and when the power came on this morning, we cannot get the TV 'ON'.There is however the TIMER light on the...
Thats a very common problem caused by weak caps on the DM board when power is lost they drain and then cannot recharge when the power is restored the WS55511 DM repair kit from www.tvrepairworld.com will usually solve that issue. The kit contains the caps and the cd with instructions.
MITSUBISHI WS-55511
Try to fix and resoldered cable connection from specifically on the horizontal and vertical panel. there some loss connection it it. but if this not solve the problem you need to test the voltage regulator that regulate the power to project the picture.
may this help,
melnavz
tip
Mitsubishi WS-55511 Manual Download
Download Mitsubishi WS-55511 HDTV Manual
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Have you misplaced your Mitsubishi WS-55511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-55511 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
____________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
on Apr 30, 2010 • Televison & Video
tip
Bypass or Reset Mitsubishi HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
The picture is bigger then the screen how do I adjust so that the picture is same size as TV thanks
Please confirm tv model number as question shows its Mitsubishi WS-55511 rear projection tv.
This info will help me to suggest a solution.
Do you get correct colors in picture though its over size?
Thanks.
tip
Bypass Mitsubishi HDTV VChip Password
I hope that helps.
tip
I hope that helps.
2helpful
Mitsubishi ws-55511 does not turn on
Listen: you need to wait for the set to first shut off! then push on the TV(not the remote) Input and Menu both at the same time for 5 seconds and then release---the power light will then blink---this model has this feature--
Mitsubishi Ws 55511
Good Day;
My opion is that the TV"s convergence Ic has failed > STK393-110 > 267P155010.
Good Luck, big IRISH.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
