Troy Bilt 21A682J766 Horse 8 HP Rear Tine Tiller Logo
Posted on May 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Adjustment for belt for 8 horse power horse. Really need to find a manual. Where can I locate one?
Tim Whalen
Level 3:
  • Master 3,076 Answers
  • Posted on May 29, 2011
Tim Whalen
Master
Level 3:
Answers
3076
Questions
0
Helped
823829
Points
9577
Http://www.hammerwall.com/Manuals/Troy-Bilt/Description/21A682J766/Troy-Bilt%208%20HP%20Rear%20Tine%20Tiller%208%20HP%20680%20Series%20Briggs%20and%20Stratton%20Engine%20Manual/275092/
2answers
Need to locate manual for wheel horse 520-HC Garden Tractor, 1988
Go here and put in your Model and serial number of the tag under the seat and you can dowload a Owners Manual. https://lookup3.toro.com/request/request.cfm
Dec 08, 2011 • Garden
I need to locate a owners manual for a wheel horse 1978 312-8 tractor
I have found this older printed manual of a Wheel Horse lawn tractor for sale on the internet.
http://www.atomicmall.com/view.php?id=705372
I have NOT located the manual for your exact model yet.
Jun 12, 2011 • Garden
I have a 40+ year year old TB Horse tiller I need to know how to tighten up the slack in th belts and adjust the reverse disk. I was only 8-9 when my mom bought it for my dad. the main number I saw was a...
Do you know what Horse Power your tiller is? I have a manual for a 7 HP Briggs Troy-bilt that I bought in 89. I presume that you replaced the original belts with new ones?
When snow is the least bit wet the blower won't pick it up and it gets cloaked in the shut. Will spraying the shut with WD40 or PAM eliminate this problem?
it sounds like you have a pretty small snow thrower, Here in northern michigan anything less than a 8 horse power will not work except on light fluffy snow. To answer your question, Yes that might help. any thing that reduces friction will make it work better. I really need a little more info before I can be of help on this. can you tell me what size (width) the blower path is, the horse power of the motor, the make of the device and also, is it one or two stage. when I hear back from you I'll try to be of more assistance.
How do u change a serpentine belt for a 1999 ford escort zx2
ADJUSTMENT 1.8L Engines ALTERNATOR AND WATER PUMP BELT
  1. Loosen the alternator adjusting bolt.
  2. Raise and safely support the vehicle.
  3. Loosen the alternator mounting bolt. NOTE: Do not pry against the stator frame. Position the prybar against a stronger point, such as the area around a case bolt. Fig. 1: A belt tension gauge should be placed on the longest span of the belt to check tension — 1.8L engine 90981g05.gif
  4. Position a suitable belt tension gauge on the longest accessible span of belt and tighten the belt.
  5. Adjust the tension to 86–103 lbs. (383–461 N) for a new belt or 68–86 lbs. (304–383 kg) for a used belt.
  6. If a belt tension gauge is not available, adjust the tension to 0.31–0.35 in. (8–9mm) deflection for a new belt or 0.35–0.39 in. (9–10mm) deflection for a used belt.
  7. Tighten the alternator adjusting bolt to 14–19 ft. lbs. (19–25 Nm).
  8. Tighten the alternator mounting bolt to 27–38 ft. lbs. (37–52 Nm).
  9. Lower the vehicle. Fig. 2: Alternator and water pump pulley belt routing — 1.8L engine 90981g06.gif
POWER STEERING PUMP BELT
  1. Raise and safely support the vehicle.
  2. Loosen the power steering pump mounting bolt and nuts.
  3. Adjust the power steering pump and, if equipped, the air conditioning compressor belt tension by turning the pump adjusting bolt. Fig. 3: Power steering pump belt routing and locations of the mounting bolts, nuts and adjusting nut — models without A/C 90981g07.gif
  4. Tighten the power steering pump mounting nut near the pump adjusting bolt.
  5. Position a suitable belt tension gauge on the longest accessible span of belt and tighten the belt.
  6. Adjust the tension to 110–132 lbs. (491–589 N) for a new belt or 95–110 lbs. (422–491 N) for a used belt.
  7. Check for proper belt deflection. For a new belt (one with less than 10 minutes of run time), the deflection should be 0.31–0.35 in. (8–9mm). For a used belt (one with more than 10 minutes of run time), the deflection should be 0.35–0.39 in. (9–10mm).
  8. Tighten the power steering pump mounting nut, located near the adjusting bolt, to 27–38 ft. lbs. (37–52 Nm).
  9. Tighten the pump mounting bolt behind the pulley to 27–40 ft. lbs. (36–54 Nm), and the remaining pump mounting nut to 23–34 ft. lbs. (31–46 Nm).
  10. Lower the vehicle. Fig. 4: Power steering pump belt routing and locations of the mounting bolts, nuts and adjusting nut — models with A/C 90981g08.gif
1.9L Engines The accessory drive belt for 1.9L engines has no provision for manual belt adjustment, since these engines use an automatic belt tensioner. Drive belt slack is taken up by the automatic tensioner. NOTE: Movement of the automatic tensioner assembly during engine operation is not a sign of a malfunctioning tensioner. This movement is the tensioner self-adjusting and is required to maintain constant belt tension. Fig. 5: Drive belt routing — 1.9L engines 86751052.gif
2.0L Engines The accessory drive belt for 2.0L engines has no provision for manual belt adjustment, since these engines use an automatic belt tensioner. Drive belt slack is taken up by the automatic tensioner. NOTE: Movement of the automatic tensioner assembly during engine operation is not a sign of a malfunctioning tensioner. This movement is the tensioner self-adjusting and is required to maintain constant belt tension. The belt tensioner has a belt length indicator. If the indicator marks are not between the MIN and MAX marks, the belt must be replaced. Fig. 6: Drive belt routing — 2.0L SOHC engine with A/C 90981g23.gif
Fig. 7: Drive belt routing — 2.0L SOHC engine without A/C 90981g24.gif
Fig. 8: Drive belt routing — 2.0L DOHC engine 90981g25.gif
When the clutch is disengaged the tines still turn.
If you email me at [email protected] I have a couple of Econo-Horse manuals that I downloaded that I can email to you. They don't really have a clutch just belts and pulleys so its probably just needing a new belt or a belt tension adjustment. I have a Econo-Horse tiller and it is a nice machine I think mine is about the same age as yours.
Good Luck,
Frank
Drive belt slipping, how to adjust
Where the lever mechanism for forward and reverse works down close to the engine mine has a bolt that you loosen and adjust the slide up and down to allow for more movement of the housing.
May 15, 2010 • Garden
6helpful
3answers
How do i adjust belt on troy bilt horse tiller
How do I tighten a belt on a troybilt Tecumseh rear tine tiller?
1helpful
I have a older troy-built tiller (horse), belts slip under load
Remove the Belt, take it to an a Auto parts store and buy a smaller one, the replacement engine may not be exactly as the old one was
Apr 18, 2009 • Garden
2answers
Belts slippin on troy bilt horse
Have you adjusted the locking cam for forward. This cam is held in place with one bolt. The further you move it down the tighter it will make the belt
Top Troy Garden Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Renee Knafel-Bullock
Are you a Troy Garden Expert? Answer questions, earn points and help others
