Whirlpool LGN2000LWH Gas Dryer Logo
Posted on May 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I access the burner to check the igniter?
Tim Whalen
Level 3:
  • Master 3,076 Answers
  • Posted on May 29, 2011
Tim Whalen
Master
Level 3:
Answers
3076
Questions
0
Helped
824412
Points
9577
Http://www.applianceaid.com/gas_dryer.html#noheat
1helpful
Dacor cooktop - one of the burners' igniter does not spark. Need to investigate what's wrong but do not know how to gain access
To access the spark module and switches underneath the spill tray of your Dacor cooktop, you may need to remove the burner and base assemblies. Here are the steps you can follow:
  1. Turn off the power to the cooktop by unplugging it or turning off the circuit breaker.
  2. Remove the grates, burner caps, and burner bases from the cooktop. Depending on the model of your Dacor cooktop, you may need to use a screwdriver or wrench to remove the screws or bolts that hold the burner bases in place.
  3. Carefully lift the spill tray out of the cooktop. If it seems to be stuck, check for any screws or bolts that might be holding it in place and remove them.
  4. Once the spill tray is removed, you should be able to access the switches and spark module underneath. Check for any loose connections or damaged components that may be causing the igniter to malfunction.
  5. If necessary, replace the faulty component or components. You can find replacement parts for your Dacor cooktop online or at a local appliance store.
  6. Reassemble the cooktop in reverse order, making sure all the components are properly aligned and securely fastened.
  7. Turn on the power and test the burner to ensure that the igniter is working properly.
Note: If you are not comfortable working with gas appliances or if you are unsure about any of the steps, it is recommended that you seek the assistance of a qualified technician.
1helpful
Dryer runs, can see burner is firing but heat setting seems stuck on ;Delicate cycle. Taking 3 hours to dry a load of towels.
gas coil condensors may not be working properly as they set the gas pressure needed to keep flame going hot. can check them with a multi meter however if flames stays on you may want to check the venting system first u might be surprised bad venting can slow down drying. check in machine and at exhaust to home. Again Each time you see the glow bar igniter come on it should ignite the gas burner. If you find the glow bar igniter glowing red for a short time and then fading off without any burner ignition would indicate weak solenoid coils. The coils are mounted on top of the gas valve and they both will need to be removed and replaced. In order to access the solenoid coils will require removing the lint filter, removing the two screws which was hidden by the lint filter and raising the top and removing the front panel.
Jan 28, 2015 • Dryers
2helpful
2answers
Broiler burns but the bottom burner on the stove will not come on the glow igniter turns orange but the burner doesn't light also one eye doesn't light, the striker sparks but the burner...
FOR THE OVEN NOT HEATING
The problem beleive it or not is that the bake igniter is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake igniter(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of igniter make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake igniter. I know it seems improbable that if the igniter comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the igniter comes on yet the oven won't heat that a weak igniter is the cause 100% of the time
FOR THE SURFACE BURNER NOT LIGHTING The holes on the burner espically those around where the electrode are dirty/clogged. By using a paper clip/safety pin to push in and clear the holes then clean the burner up with some steel wool the burner should light. GENE
Front burner will not light the igniter is good it woks in the other burner and i put a good igniter in the burner and it will not work
What happens when you use a long match or a long butane lighter? Does the gas ignite?
Since the igniter is working in another burner, then either the gas isn't getting to the burner (sealed burner blocked), the spark is being blocked or the electrical connection to the igniter is bad.
Take apart the burner and clean the openings. Make sure that the hole in the part that slides over the electrode is clear (use a needle or the wire from a twist-tie). See page 28 of the manual. (available online from http://www.geappliances.com/service_and_support/literature/ . Enter the model and click submit). Make sure you replace the parts of the burner correctly.
My range also has an orifice at each burner that could be blocked. Turn off the gas before investigating this. Look at the instructions for converting the range from NG to LP - this should be attached to the back of the range near the regulator. This will tell you how to access the orifice and what size wrench to use. I believe my range uses 10 mm.
To check the wiring, you may need to lift the cook top. Often the top is secured with clips on the left and right sides.
I hope this helps.
1helpful
I need to know were i find the igniter on my kenmore 70 series and replace it
Thi igniter is on the burner assy located in the bottom of the dryer. This manual will tell you how to open your dryer. It does not tell you how to change the igniter but it does show how to access the burner. The igniter change out is a matter of unmounting the existing one and unplugging the connector then install the new one. The burner access is through the toe panel discussed in the manual link above.
If you need more assistance would provide your model number please so we both can refer to the correct data.
Thanks for using FixYa,
Kelly
5helpful
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 • GE Ovens
    The igniters on the left side on my Tappan gas range.
    may need to disconnect voltage to machine,and check for a loose wire to burner knob.may need to lift top.to access this area.
    2answers
    New brinkman gas grill---side burner lights on ignition control but main burners do not light with ignition control---am able to match light the main burners----any ideas anybody
    Clean or replace the main igniter. The backs corrode and need to be cleaned or replaced. Home Depot carry replacement parts.
    Apr 25, 2009 • Grilling
    Replacing Oven Igniter
    PULL OUT THE DRAWER AND THAT WILL ALLOW YOU ACCESS TO THE 1/4" SCREWS IN THE LOWER REAR THAT HOLDS THE BURNER IN PLACE ALONG WITH THE FRONT SINGLE 1/4" SCREW. NEED A FLASHLIGHT FOR THIS. THIS FREES UP THE BURNER SO YOU CAN ACCESS THE IGNITER MOUNT SCREWS.
    Top Whirlpool Dryers Experts
    Virgil Watts
    Paul Bade
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
