Our Dishwasher doesn't want to get fill or start.. I press the buttons and the lights turn on and then I press start and nothing happens so the lights turns off. The water doesn't seem to want to come out but, we put water to see if it drain and the water drain good. Please help me here Thanks Dianne
Hello Dianne...I'll take a shot here.. chances are that the door interlock ( switch ) is disabling the dishwasher from starting.. it may be damaged or disconnected.. and as long as you are sure you have a water supply to the dishwasher,.. that's where I would start...If that switch is NOT made.. the dishwasher will not start... Hope that helps
Hi
Intake/Drain light flashing means an issue while
draining. You would need to check for air gap on the dishwasher, it may be
clogged. It prevents dishwasher from draining, sometimes the drain flow is
restricted due to gunk. Cleaning or bypassing the air gap will resolve the
issue. If this doesn't resolve the issue then it is due to seized (or stuck)
drain pump. Disconnect the power to the dishwasher or turn off the breaker to
the dishwasher. Tip machine on its back; remove screws that hold the bottom tray
on. Remove the hoses to the main motor, remove electrical connections &
remove motor (single screw holds motor, it is on the outside back of the
machine). Try to rotate the motor (use WD40 is necessary). If you cannot rotate
it, then motor will be required. If the error still appears then cancel the
error message, turn the rotary selector switch to "Stop/End" or press
the "Start/Stop" switch for approx. 5 secs. Switch the appliance off
and then back on again. Hope this helps... Please post back if you need more
information.
Daniel
