SOURCE: go video gv6060
I have exactly the same problem-tapes will not eject on either deck and I keep getting "ERROR" on front display. I've been asking for help on this for awhile now. I've taken the cover off and can't make sense of anything inside. Is there a video or manual available somewhere where there are pictures describing/showing the parts involved, so I can make sense of it and not ruin anything? Thanks!
SOURCE: "Dead"
Sounds like the chipboard has blown. You could try pulling the unit apart and see if there is a burn on it not always easy to see but if there is you may as well buy a new one. If not it maybe the power supply regulator has blown which is more likly and this can be replaced but is expencive to do.
SOURCE: I have very old VCR tapes which has distorted display.
The best way to go would be to get a VCR with a USB and connect it to a PC. You can get programs such as Magix from Amazon that will restore the pctures and then put them on a DVD or even Blue-Ray drive.
SOURCE: I need a new remote for this unit. Where can I buy
The new remote is easy. An substitute remote is available here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=GV4060&uuid=12918561936090 . This should match most of the features of the original.
For the ghosting, the first thing to check is the cables. Try new A/V cables and make sure that they are well seated in both sets of jacks. If changing the cables doesn't help, I suspect that the connection between the video jack and the input board has a problem. This may be correctable if you can solder and are willing to open up the unit. You would need to remove the old solder and then resolder the joint. Alternatively, see if the input board is available from somewhere and just replace it. You need to read the part number off the board and google that part. (My usual source doesn't list this device but the parts are often shared.)
(This assumes the Sony DVD/VCR unit is compatible with providing a signal to a second VCR. Some are not and you may have gotten lucky with the previous Go Video unit.)
I hope this helps.
(a second possibility for the ghosting is that the video board has a problem but that is unlikely. Since you aren't reporting a problem with video playing in the Rio unit.)
