Cars & Trucks Logo
A
Anonymous Posted on May 29, 2011
Immobiliser - Autowatch 629 Ti I have purchased a autowatch 629 Ti immobiliser. There is a wiring diagram which is not helpful. I need to know which wires the circuit 1 wires and circuit 2 wires from the wire harness attach to. The diagram show that you have to cut circuits to be immobilised. But there is no explaination what circuits to cut ,these wire are are where they come from. Therefore I do not know which wires to cut so that I can attach circuit 1 and circuit 2. The rest of the diagram is fine except which wires to connect circuit 1 and circuit 2.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 16, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1973
Points
Hi mate you able to post up the diagram
cheers
Please help with this autowatch 4 door closer system
  1. Check the wiring: Make sure that all of the wiring connected to the door closer system is properly connected and secure. Check for any loose or frayed wires that may have been disconnected during the battery disconnect.
  2. Reset the system: Try resetting the system by disconnecting the battery again and holding the brake pedal down for 30 seconds. Then reconnect the battery and see if the system starts working properly.
  3. Check the fuses: Check the fuses associated with the door closer system to ensure they are not blown.
  4. Contact a professional: If you are unable to resolve the issue on your own, contact a professional who specializes in car alarm systems to diagnose and repair the problem.
If you still cannot get the door closer system to function properly, it may be necessary to have it serviced or replaced.
Can you help ? looking for a autowatch 695 wiring diagram
The best solution you'll get from books at www.reliable-store.com
These are books containing info on repair, service, troubleshooting, parts info, assembling dissemble, removal, error/fault codes, wiring diagrams and everything on any vehicles cars, atv, trucks. forklifts, boats, excavators etc
How can i bypass the alarm/immobiliser on Autowatch 446RLI the car battery died, after charging the car battery the car won't start. it is dead quite when turning the key even thou the dash is lit.
Try getting a friend to boost start your battery with his vehicle and see if your car will crank. If your car cranks over - you have a faulty battery.
Check your battery leads, particularly the black earth lead where it connects to the engine/bodywork.
It's worth pointing out that a failed battery will charge up to a certain extent - however there isn't sufficient power in that battery to crank the engine even though all your dashboard lights are illuminated.
Get somebody to try boost-starting your battery first.
If you're sure that your battery is ok (or if connected to another vehicle): Put your ignition key in and turn it on/off a few times. Leave it in the 'on' position for 2-3 minutes. Give the system time to re-recognise the key
It actually sounds to be battery problem
jump start vehicle Google Search
What's your question? wiring diagram for alarm 280rl
Do you have the instalation diagram for autowatch alarm 28rl
Immobiliser
I regret ti inform you we have no wiring diagrams availiable
1helpful
Autowatch 280rl alarms wiring diagrams
Where can I find a autowatch 280rl wiring diagram Thank you
1helpful
1helpful
Ford Courier Van imobiliser stuck on
hi not as simple as that have you checked all the fuses and corresponding relays and wiring connectors there is a web site that gives you the wiring diagrams for the security systems if you are ok with wiring diagrams then you will either be able to by-pass or or put a remote start switch in but as i said it is not a five miniute job if you want i can send you the sites details yates210456
Top Toyota Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Toyota Expert? Answer questions, earn points and help others
